Author Topic: 32 bit vrs 64 bit Win7  (Read 2368 times)
W7ETA
« on: March 26, 2012, 08:58:31 PM »
Is the 64 bit version of Win7 compatible with SDRs (or, will the software run in Win7 64 bit)?  I'm starting out with Softrock kits and plan to set up a computer in my ham radio play room for just ham radio. So. finding other programs that will work with Win7 64 bit should not be a problem?
If there will be problems will going to XP 64 bit solve those problems?
Bob
KA4POL
« Reply #1 on: March 26, 2012, 09:49:36 PM »
You'll get an Error: Windows 7 64 bit driver not signed.
This says already what the problem is.
All 64 bit versions of Windows from Vista through Windows 7 must use signed drivers. There is a workaround. You'll have to hold the F8 key while booting. You'll see a menu which provides you a choice to run without driver checking. One of the options of this Safe Mode boot menu is to permit unsigned drivers. This will allow those drivers to be used. Every time you want to use a program that requires an unsigned driver you have to have to use the F8 key on boot up, no way to switch to a permanent version. And while doing that say a big thank you to Microsoft.
W7ETA
« Reply #2 on: March 27, 2012, 12:41:27 AM »
Tks for the info OM.
Bob
KA4POL
« Reply #3 on: March 27, 2012, 01:52:45 AM »
You're quite welcome.
73 Dieter
KE5JPP
« Reply #4 on: March 27, 2012, 12:41:42 PM »
Your information is generally outdated.  That is only true for some of the (very few) drivers that have not been updated yet.  Most SDRs, including Flex Radio SDRs, now have signed drivers so there is no need to use the F8 key bypass.   There is absolutely no reason not to use the 64 bit version of Windows 7 now, especially when it allows you to make use of > 3 GBytes RAM where Windows 7 32 bit does not.
Gene
« Last Edit: March 28, 2012, 01:16:15 PM by KE5JPP » Logged
