Author Topic: Donner's Digital Interface and CWGet  (Read 1913 times)
ZL4JB
« on: July 11, 2006, 01:54:25 PM »
Good day all,
I have an interface from Donner's Digital folks and am trying to use it to receive morse code with CWGet.  I thought it would help in those high speed CW contests - it couldn't hurt.  I am using a Kenwood 440 with my computer.  I have used the interface for psk31 with Digipan - no problems there.  But I am not having any luck thus far getting CWGet to copy anything on the bands.  Has anyone used this interface with CWGet, or is there some simple point I am missing, or can I not use the interface with CWGet?  Any thoughts and opinions and ideas would be much appreciated.
73's
JIM
ZL4JB
N0IU
« Reply #1 on: July 12, 2006, 11:03:07 PM »
I have this program but I don't use this interface. Since it works with PSK31, I would tend to think that the interface is not the problem. Do you see anything on the CWGet screen? You should be seeing peaks that correspond with the frequency of the signal. If you don't see these peaks, that means the program is not receiving the audio. If you are seeing the peaks, you have to move the vertical red line onto the peak and you should start seeing it decode the signal.
Scott N0IU
W0RY
« Reply #2 on: July 21, 2006, 08:27:53 PM »
Try using HamScope.
http://www.qsl.net/hamscope/HamScope.html
This is what I use for CW/PSK/RTTY with my Donner's Digital Interface.
Bob,  http://software.bobv.name
corrected URL  7-4-2015
« Last Edit: July 04, 2015, 10:20:42 AM by W0RY » Logged
