Author Topic: Coiling excess coax in mobile rig  (Read 6578 times)
KK4IKO
« on: April 04, 2012, 12:41:53 PM »
I'm going to have about 9' of excess coax when I finish my mobile rig setup.  I've read lots of stuff on the effects of coiling the excess or not, but those folks can't seem to agree (mostly CBers) on what to do.  I'll be on 2 and 6 meters mostly.  Since I don't have the PL-259 installed yet, is cutting to fit an option?  The setup is a Larsen 5/8 wave mobile on a Larsen NMO mount going to an appropriate duplexer and then to the IC706MKIIG radio.
No callsign yet, I'm taking the test on Saturday.
« Reply #1 on: April 04, 2012, 01:00:54 PM »
 Cutting to fit will slightly decrease the coax losses:  by about 0.4dB
according to VK1OD's transmission line loss calculator:
http://www.vk1od.net/calc/tl/tllc.php
On the other hand, simply coiling it up is fine, and gives you the option
to pull it out for maintenance, or to set the rig on the outside of the car
when operating in the field, etc.
KB1GTX
« Reply #2 on: April 04, 2012, 08:05:35 PM »
Go ahead and coil it.
The cb'ers got that don't coil the coax from instaling cb's on non metalic boats where the coax run worked as the ground plane.
« Reply #3 on: April 04, 2012, 10:27:40 PM »
I'd coil it, and I'd put the coil under a seat or somewhere else that offers some protection from being crushed. I'd also make the coil radius fairly large as that's less mechanical stress and good VHF practice involves gentle transitions from a straight run.......
" It ain't ignorance that causes all the trouble in this world.  It's the things people know that ain't so... "   ---   Edwin Howard Armstrong
W5DXP
« Reply #4 on: April 05, 2012, 04:31:50 AM »
Something else to consider: Coiling has an effect on common mode currents on the coax and is often used at HF as an "ugly balun" to reduce common mode problems.
WA3SKN
« Reply #5 on: April 05, 2012, 05:42:36 AM »
9 Ft of coax is not that much, unless you are using RG179 or such... so there should not be a problem in coiling it.  But you can cut to fix, if desired, just to improve appearance.  And if there is any real problems (with common-mode, etc.) you will want to address it anyway!
Good luck with the test!
73s.
-Mike.
N4CR
« Reply #6 on: April 05, 2012, 06:52:28 PM »
Good luck on your test!!
You can just coil up extra coax with no noticeable effect. Larson makes exceptionally nice mounts and antennas. You'll have a great installation even with it coiled up. Don't make the coils too small but the diameter of a 2 liter bottle would be fine.
Welcome to the hobby!
73 de N4CR, Phil
« Reply #7 on: April 07, 2012, 12:24:54 PM »
If  it already has a connector  then coil it up and shtash it out of the way. If it has no  connector on it and it will be staying in this car, then cut it to fit, and save a bit of loss.
KK4IKO
« Reply #8 on: April 08, 2012, 06:03:04 PM »
Thanks for all your help.  I passed my test, looking for my callsign in the next week or so.  I completed the installation and gave the radio a listen.  All I got was a weak conversation accompanied by lots of static on 147.45.  I would suppose the fact I live in a narrow north/south mountain valley with ridges on 3 sides didn't help.  Later this week, I'm going mountain-topping.
N4NYY
« Reply #9 on: April 08, 2012, 07:38:13 PM »
Do yourself a favor and do not be like me, where my work frequents parking garages, many of the 7 foot clearance variety. I cannot even put on a 2M magmount, or I will destroy it. Believe me when I say, you will forget.
Congrats on the license and stay the hell away from parking garages!
KK4IKO
« Reply #10 on: April 09, 2012, 04:32:47 AM »
Good point about parking garages...never really thought about it because I use them very infrequently.  I'll put a reminder on the dash, LOL.
« Reply #11 on: April 09, 2012, 12:33:05 PM »
a small 2m antenna on a trunk lip mount will be ok for repeaters and will be below the roof line and no thought necessary...Smiley  my kind of antenna
W0FM
« Reply #12 on: April 12, 2012, 11:58:06 AM »
I like that, Tom....."NTN".  No Thought Necessary.  I think I'll make all my future projects the "NTN" variety.  Not getting any younger, ya know.  ;o)
Terry WØFM
« Reply #13 on: April 12, 2012, 02:25:06 PM »
Heck I have a second one on the other side of the trunk lid for the 900 radio.  After the first time I ran it through the "free" car wash at the gas station, I realized I don't have to take them off there either.  On the other side of it, in my truck I have a ladder rack, 4 antennas on the roof and 4 antennas on the bed rails, and the tallest is over 10 feet, and it always wakes me up when I forget it is there.  The tallest is a 60 inch whip on a bed mounted DK 3, so it is a tough old  bird and it always reminds me that I have antenns upo there... ot does the word "twang" come to mind:)
KK4IKO
« Reply #14 on: April 12, 2012, 05:16:34 PM »
Now if I could only get the forum guru to recognize the fact I have filled out his little form to change to my new callsign 2 days ago, I'll appear to be a little more official looking.
Anyway, just for the record, I'm now KK4IKO.
I have just one antenna, on the roof of my Cherokee.  A ham friend is going to help me get on the air this weekend.
You elmers are great!
