This Sunday evening, the Flying Pigs Amateur Radio Club International will be holding its monthly Run For The Bacon. This is a friendly, two hour QRP CW Sprint, which is open to ALL radio amateurs, will last from 9:00 - 11:00PM EDT (0200-0400 UTC Monday).
You may work stations once per band on 160, 80, 40, 20, 15 or 10 Meters. Suggested starting frequencies are 1.812, 3.562, 7.044, 14.062, 21.062, and 28.062 MHz.
The exchange is RST, S/P/C (State, Province, Country) and Flying Pigs membership number. If you're not a member of the Flying Pigs, and would like to be; then please click on the "membership" hyperlink on
http://www.fpqrp.com/. Otherwise, non-members can just use their output power figure.
You can report your score via the Autolog page which can be found at :http://www.fpqrp.com/fpqrprun.html;
or you can mail your logs to the address given on the Autolog page. The deadline for logs is October 22nd at 2400 UTC.
As like last month, the top three scorers will win a certificate. Keep in mind that anyone who participates in 10 out of 12 RFTBs this year will earn a special Certificate of Merit at the end of the year. So please use the Autolog if you've participated; but were unfortunate enough to make any contacts. In this case, trying helps!
Hope to catch you on the air Sunday evening!
72 es "oo"
Larry W2LJ FP#612
