Author Topic: Program for print QSL card , envelope , find address direct send  (Read 1131 times)
SP9AUV
« on: April 28, 2012, 12:09:08 PM »
Hello all friends !
I would like to inform all ham's that on my english website
        http://sp9auv.com/EN
in a chapter
http://sp9auv.com/EN/index.html?downloading_program.php
I put program  HAM SECRETARY  for print QSL cards
with this posibility :
print QSL cards, labels, envelopes, bookmarks between cards
  directly from the program HAM_SECRETARY - without using
  MS Word Mail Merge methodology
-print bookmarks between cards for sending or for home archive card
- It is a contextual help Chm file- ie pressing F1 in the program  results open to
  place in the  help description of function what actualy  do.
- For the users logger program Logger32 , MixW  and  Ham-Radio de Luxe
  in a help hile is writed separately topic how select and collect data file
  (any .adi . csv .txt format)  for printing it with use HAM_SECRETARY program
- download address for sending cards direct from QRZ.COM
   for station who must send DIRECT  QSL card or for any station
- print envelopes for send direct QSL card . Address is  taken from QRZ.COM
- Sorting printed QSL cards or labels according to the chosen    criterion sorting
   (according to the DXCC list, by ADIF,  or  the callsign)  --- with switching
   order for cards to be sent  via the QSL Manager to the country QSL Manager
- QSL cards separation to be sent DIRECT
- The format of the data file of QSO's can be any: ADIF, csv, text
- checking if for callsign is present QSL bureau
- Translation files between any formats - ADIF - csv - txt - cbr  to any other format.
- Create files Cabrillo format standard 2.0 or 3.0 for contest
- printing is based on patterns of print that can be individually designed by the program.
- with the program are provided a print patterns for labels that match each station,
  since personal data are collected from a set setup.ini
- Insert any graphic images
- print design patterns using a method WYSIWYG. On the
  screen do not see the names but the data  collected from the test QSO data .
- print pattern can be designed based on the scan QSL  which
  ensures perfect positioning of fields
and print it  the first time  after the design pattern
  For this pattern  look at this link
 http://sp9auv.com/Pliki/qsl_scan_postac_konc_wzorca_en.jpg
- If you receive QSL cards from printing house  too small or too large
   there are no problem because program can move your card on a  A4
   printing  area  -  for example  your pattern was design to 140 x 90 mm card
   but from  printing house you got 142 x 92 mm - then you can move
   your card on a printing  area  - look at link
                       http://sp9auv.com/Pliki/Option_print_HS_V2_3_0.jpg
  This moving is remember by program for next printing
- PROGRAM is very helpful to print a QSL card in the mass including for the
  DX-expedition STATIONS - can print 6000 QSO - QSL card or 18000 labels
  in one proces print
                          Best regards Vy 73 de Jerzy SP9AUV
