Author Topic: ? on assembling a 1/4" phono plug and cable  (Read 2106 times)
W1NJ
« on: December 05, 2006, 09:03:18 PM »
I just purchased a set of iambic paddles...I forgot to order the plug and cable.  Can anyone out their provide some advice and instructions on how I can make my own?
de W1NJ
W1NJ
« Reply #1 on: December 05, 2006, 10:33:01 PM »
can anyone out THERE not their...oops, just read my own post...sorry about the poor grammar!
W1NJ
KB9CRY
« Reply #2 on: December 06, 2006, 05:46:57 AM »
Well you connect some wire from the paddles to the plug.  Personally I use small coax cable to connect mine to my plug RG-58AU or even smaller will work well.
I believe the connections are screw on at the paddle side and I solder my wires on my plug connectors.
W5ESE
« Reply #3 on: December 06, 2006, 07:07:26 AM »
My rig uses a smaller plug; the 1/8" phono
plug.
For the connecting cable, I harvested the
multiconductor cable off a discarded computer
mouse.
It looks good and works well.
Scott
W1NJ
« Reply #4 on: December 06, 2006, 02:06:16 PM »
thank you guys for the advice...it is appreciated.
de W1NJ
N3EF
« Reply #5 on: December 06, 2006, 02:41:52 PM »
  I also use mouse cables. Small diameter and very flexible. I don't see how you can use coax cable as you need three conductors for paddles. I also suggest using 3.5mm/1/8" plug as that is what most newer rigs use and just use a 1/4" to 3.5mm/1/8" adapter if needed.
Eric N3EF
K5CQB
« Reply #6 on: December 06, 2006, 03:32:09 PM »
I used one of Radio Shacks microphone cables.  They are 6ft long, I cut them in half and now have two cables with a plug already mounted.  There are three conductors and they are copper so you can solder them if needed.
Radio Shack part number 42-2616.
Jim
W1NJ
« Reply #7 on: December 07, 2006, 08:45:26 PM »
Thanks to all.  I cut an old mouse cord and the diameter of the wire was too thin (plus there was an extra conductor cable)...I am going to give the Rad Shack mic cable a try.  The rig is a FT-990.  Growing up my uncle, K1IAL, always took care of this stuff for me...been away from the hobby for some time.  I will see you on 40 CW (still the most fun mode in the hobby).
de W1NJ
W5ESE
« Reply #8 on: December 08, 2006, 10:58:03 AM »
> cable)
yes, the wire in mouse cables is pretty thin.
since there are 4 conductors, i just connect
two in parallel to ground (the center post).
then the remaining 2 wires to the "ditter"
and "daher".
the mouse cable is pretty small for the 1/4"
plug; it's a much better fit for the 1/8"
plug.
scott
K7NHB
« Reply #9 on: December 15, 2006, 10:51:20 PM »
Remember to check your rig to see whether the rig or the tip should be the dit and dah. On my Ten Tec Argo V, the tip is the dit, ring is the dah. but on the MFJ keyer, the dah is the tip and the dit is the ring. Check before you connect it up. 73, Paul
NS6Y_
« Reply #10 on: December 16, 2006, 03:59:32 AM »
Bloody hell.
OK one way to do it is, get something with a stereo plug built on, like an old set of headphones or a stereo-stereo cable from Fry's and use that. Figure out if dit is tip and dah is ring and all that, and wire it up.
I like that approach myself, those headphone etc cables tend to be shielded and done right, all you have to worry about is the pinout.
KC0VCU
« Reply #11 on: December 29, 2006, 03:59:23 AM »
One other thing with using the headphone cables, if you crimp on connectors, you can fairly easily re-arrange the wires if you discover you have the conductors reversed.
As noted earlier, check your radio manual, you should be able to find the correct pinout for your radio/paddle setup.
-Rusty - kc0vcu
