Author Topic: HRD FOR FT 847  (Read 866 times)
N4MJG
« on: May 10, 2012, 08:56:12 PM »
Hi guys !
got question for you guys has anyone ever run HRD on ft-847 base what i saw on website from HRD it shows it will work on 847 ! my question does it run on data cable on back of 847 what about run with singlelink? or what ever it called ! i know i can run with 897D,it would be nice if i can run 847 and let my Girlfriend use the 897D so she can check in 2 meter net handle talk don't do too well in her apt. !:/
I just wanted to know if impossble to use 847 on HRD ! I would love to use my 847 Smiley
Jackie
N4MJG
GENEREAL LIC.
BEEN HAMMING SINCE 2001
N5VTU
« Reply #1 on: May 11, 2012, 08:27:42 AM »
Jackie,
The FT-847 will run on HRD using the 9 pin D-sub connector on the back of the FT-847.  It's been a long time since I've had them connected, but the point is it did work.  If I recall, I had to set the baud rate fairly slow to make it happen, like 9600 or so, but that may have been a function of the serial card in my pc, not anything to do with the software. This was with one of the 4.x versions of HRD.  I have not tired using any of the HRD version 5.x with the FT-847.
I don't know anything about the Signalink.
If you don't get any more help here, you might try asking in the Digital forum.
Stephen
N5VTU
