Author Topic: HRD FOR 847  (Read 586 times)
N4MJG
« on: May 11, 2012, 09:31:07 PM »
Hi guys !
got question for you guys has anyone ever run HRD on ft-847 base what i saw on website from HRD it shows it will work on 847 ! my question does it run on data cable on back of 847 what about run with singlelink? or what ever it called ! i know i can run with 897D,it would be nice if i can run 847 and let my Girlfriend use the 897D so she can check in 2 meter net handle talk don't do too well in her apt. !:/
I just wanted to know if impossble to use 847 on HRD ! I would love to use my 847
Jackie
N4MJG
GENEREAL LIC.
BEEN HAMMING SINCE 2001
VA7CPC
« Reply #1 on: May 12, 2012, 05:21:19 PM »
A few points:
1.  HRD lists the FT-847 as a supported radio.  So you should be OK, there -- the FT-847 _does_ support computer control (CAT).
3.  If your computer has a serial port, you may need an adapter to converter the serial-port voltage levels to the FT-847 CAT levels.  If your computer has a USB port, you can use the adapter cable you'll find when you search eBay for
. . .    FT-847 CAT
4.  If the SignaLink has a 6-pin "mini-DIN" plug, it will probably work on the FT-847 _if_ the FT-847 has a "data jack" with a 6--in mini-DIN socket.
5.  Read this article -- you may need just DM780 (the HRD digital-modes program), not the full-blown HRD CAT package:
http://www.eham.net/articles/23794
                 Charles
