Author Topic: Ultra high quality VGA cable?  (Read 1970 times)
VA2FSQ
« on: May 17, 2012, 02:56:56 PM »
Does anyone know where I can get a top quality VGA cable of 10' in length?  I've already tried some "High" quality ones including a 50$ monster cable and it is not good enough. a 6' one is ok but I need 10'
It is a pretty noisy environment. It is running from my Elecraft P3 SVGA to a frame capture board on my computer.  It has the usual radio, amps, etc in the way.  When I go to the 16' Monster cable I get some jitter in the signal which doesn't exist even with an el-cheapo 6' version.
Thanks in advancce
VA2FSQ
K9IUQ
« Reply #1 on: May 18, 2012, 10:10:39 AM »
Buy and use some High Quality ferrites on the cable.
Stan K9IUQ
TANAKASAN
« Reply #2 on: June 02, 2012, 12:14:34 AM »
You could always make your own. Start off with two connectors and thirty feet of high quality 75 ohm coax for your RGB signals then use a ten foot length of shielded ethernet cable with the plugs cut off for the rest of the connections.
Tanakasan
