Author Topic: HiFer Beacons  (Read 23242 times)
W4OP
« on: June 15, 2012, 09:20:03 AM »
Does anyone else monitor the beacons on 13.555MHz +/-?
Currently hearing WV on 13.55567MHz running 4mW into a vertical:
http://www.wa8ywo.com/HiFerbeacon.html
A couple nights back I copied MTI also running 4mW on13.557.540. I saw MTI earlier on the Elecraft P3, but he has faded now.
Fun stuff.
Dale W4OP
K0OD
« Reply #1 on: June 15, 2012, 06:22:43 PM »
Dale, I've had a receiver parked on 13.555 for the past two hours and hear nothing in St. Louis.
Anyone else?
VE7SHM
« Reply #2 on: June 17, 2012, 08:56:22 AM »
This is what i hear west coast of Canada
K0OD
« Reply #3 on: June 17, 2012, 06:49:25 PM »
I was getting the same pulsing/swishing sound in Missouri yesterday. Sounds like CODAR, oceanographic wave radar. Covers a wide swath of spectrum around 13.555.
Anybody else?
NU1O
« Reply #4 on: June 18, 2012, 01:42:21 AM »
I never even heard of these beacons before.  What is the most distant report you have received?
Chris/NU1O
K0OD
« Reply #5 on: June 18, 2012, 06:20:51 PM »
Very wide and obnoxious CODAR peaking S-9 here around 13.440 MHz. This is the kind of garbage hams labored to get moved out of the 60 meter ham band about a year ago.
http://www.n4ip.com/N4IP_Labs/CODAR-WERA.html
« Last Edit: June 18, 2012, 06:29:05 PM by K0OD » Logged
W4OP
« Reply #6 on: June 19, 2012, 10:26:49 AM »
Hifer beacon EH has been in here all day (EM85). Running very narrow FSK- maybe 1 or 2Hz shift. You'll need to be running ARGO or have  a waterfall panadapter to be able to visually decode him, but he is loud.
Here's a link to the operation:
http://vk2xv-hifer.blogspot.com/2012/04/third-hifer-beacon-seen-eh.html
He is 702 miles from me and I copy him on 13555.451KHz.
Dale W4OP
W4OP
« Reply #7 on: June 19, 2012, 03:16:33 PM »
Now seeing beacon RY very strong in QRSS mode on 13555.386KHz. 906 miles away.
Also beginning to see another beacon about 19Hz lower, but I cannot yet make him out.
Dale W4OP
W4OP
« Reply #8 on: June 19, 2012, 06:13:52 PM »
MP in Ontario is now copyable on 13555.390 KHz. 552 Miles.
Dale W4OP
W7ASA
« Reply #9 on: July 04, 2012, 06:55:59 PM »
I had copied GNK (Madison, Wi) several times in the 13 MHz region.  At first I thought that I was receiving a spur from a British maritime station of the same call, but as it turned-out, they were long extinct on CW like most of the rest of the shore stations.  :^(   Some web searching turned up the HiFER beacon GNK, a bit less than 4 milliWatts into a short, wire dipole, zig-zagged to make it fit into an attic.  I sent an e-mail and received an e-mail confirmation and more information about the HiFer beacons and the lowfer list.
<4 milliWatts, minus the feeder, minue the compromises in the antenna , the absorption in the attic and roofing...and etc.    simply amazing!
de Ray
W7ASA ..._ ._
W4OP
« Reply #10 on: July 11, 2012, 11:14:55 AM »
I have posted an ARGO software (http://www.weaksignals.com/) screen capture I made a couple days ago centered on 13.5554 MHz. From bottom to top:  EH    SIW     RY     MP
http://www.parelectronics.com/images/ARGO00000.jpg
Dale W4OP
