Author Topic: Antennas OTHER than Elk and Arrow  (Read 8221 times)
K6LCS
« on: June 19, 2012, 02:20:16 PM »
Yes, the Arrow Satelllite Antennas and the Elk Log Periodics are wonderful antennas for working the FM VHF/UHF satellites. But either cost over $125 ...
But how about spending about $100 LESS than the cost of an Elk or Arrow to get into the world of high gain?
Build yourself a tape measure beam! (Link on the ANTENNAS page at ...
http://www.work-sat.com
I built one following those plans to the letter - and have worked the FM sats with it. Yes, I know it is not engineered to receive on 440 ... but it works.
Connected it to my FT-60R, and I heard the San Diego NOAA WX frequency for the first time ever with a handheld radio from my house in Jurupa Valley.
These are fun to build ... fun to show to non-ham friends ... and always a conversation-starter!
Clint
Clint Bradford, K6LCS
KB2FCV
« Reply #1 on: June 20, 2012, 08:02:22 AM »
I built the wa5vjb yagi(s) for my antenna. It's cross polarized and looks very similar to the arrow antenna, but with a $20 price tag vs a $125+ price tag. I picked up some 1/8" aluminum rod and 1/8" brass rod and all drilled into a 1/2" square wood boom. Cheap, easy and works great.
« Reply #2 on: June 21, 2012, 08:48:48 AM »
Tape measure elements are great for use in the bush where you have to worry about
the elements hitting tree branches -I've built quite a few of them.  But the steel elements
have more loss than copper or aluminum, especially at VHF.
If I don't plan to use an antenna while running through the woods, I also prefer the
WA5VJB technique, using #8 aluminum ground wire for the parasitic elements and
#12 solid copper house wire for the driven element (so I can solder to it), assembled
on a length of PVC pipe.  (I rotate the driven element around the axis so the short
side is in front of the long side - that is easier to build.)
The half-folded driven element steps the feedpoint impedance up by a factor of 4,
just like a regular folded dipole, so if you are designing your own antennas you can
aim for 12.5 ohms to get a 50 ohm match or 18.75 ohms for 75 ohm feed.
http://wa5vjb.com/references.html
[edited to add]  $20 for an antenna?  That seems high.   Radio Shack used to sell
40' of the aluminum wire for $6, and I've got plenty of scrap PVC pipe and wire around.
But I guess some folks would rather have their pipe look clean...
« Last Edit: June 21, 2012, 08:52:53 AM by WB6BYU » Logged
KB2FCV
« Reply #3 on: August 29, 2012, 11:40:48 AM »
I stand corrected. We made about 24 of these for a club project. I found my spreadsheet I made of the cost breakdown. The cost per antenna was $17.30 soup to nuts - that is everything right down to the epoxy to hold the rods in place.
W9GB
« Reply #4 on: September 02, 2012, 03:44:22 PM »
Quote from: WB6BYU
YES, that is correct.
Commodity prices, whether Agricultural (corn, beans) or Metals (aluminum, copper) have INFLATED substantially over past 10 years.  I have not seen Alumnum ground wire, at a Radio Shack (at that price), since the Millennium started.
SCRAP is a GOOD SOURCE, but around here --
trucks roam towns and neighborhoods constantly on the Hunt of Scrap Metal for $$$.
« Last Edit: September 02, 2012, 03:45:55 PM by W9GB » Logged
