Author Topic: Yaesu FT-1802 stuck PTT?  (Read 5209 times)
KD8KLB
« on: June 20, 2012, 08:17:07 PM »
Hello All,
Yep I'm a newbie.
I have the above rig, I've had it for about 3 yrs now. And for the last three years I lived in a remote area (my neighbors were Amish), and never made a contact.
Now I am living "in a big city" but I am not sure if my rig is broke or I'm just not operating it correctly.
The local repeater is 146.160 +103.5 PL, I've set the CCTS tone, but I seem unable to TX.
if I disconnect the mic, and plug it back in the radio tells me I am transmitting. If I power off and restart the unit, I do not get the TX indicator, but then I cannot transmit.
It seems my mic is to blame, but if it is how do I fix it? Is there anything else to try first?
Mon
AJ8L
« Reply #1 on: June 21, 2012, 03:58:04 AM »
I would take the mic apart and check the ptt switch with a meter to see if it is stuck. If not then check the mic wiring to make sure it is wired correctly. You should have a pinout drawing of the mic plug in the manual. It should be pretty straight forward. Geoff, AJ8L.
KD8KLB
« Reply #2 on: June 22, 2012, 04:58:46 AM »
Thank you for answering.
Mon
KDKLB
KG6BRG
« Reply #3 on: July 26, 2012, 06:31:38 AM »
Something else you might try is to be sure you have no offset, "+" or "-" and try TX on simplex. Listen on a second receiver if possible.  If you have a vswr / power meter, put that in series too.  Then you can see what is really going on.  good luck.
K1CJS
« Reply #4 on: July 27, 2012, 05:54:53 AM »
Not to shoot you down, but that won't help with the problem he's having.  It sounds like either a transistor switch in either the mike or the rig is shorted or that the mike wiring is shorted--in the mike or the rig.
See if you can borrow another mike--or try your mike on another rig.  That will tell you where the problem is--the mike or the rig.  Other than that, I can't guide you further, you'll have to either send it for repair or get it to a local troubleshooter in your area.
