Author Topic: FT-450D receive problem  (Read 13001 times)
K8AEC
« on: June 21, 2012, 06:36:42 AM »
Greetings,
   Here is my problem:
The other day I switched to my CB radio from the FT-450D (i use a standard switchbox).   I use the HF on 20m with an A-99.   I made sure the HF rig was off, then switched the to the CB (the A-99 in use).
   I talked for a few minutes, then realized I hadn't re-tuned the tuner for 11 meters, which no doubt caused a high SWR.   I didn't key down very long and it was a short conversation.   A few hours later I switched the box back to the FT-450D and noticed the receive on 20m was lower than normal.
     Could I have somehow damaged the FT-450D with a high SWR on the CB?   I've tried a direct connection to the 450D and the A-99 and do not notice a difference in signal strength than when the A-99 is running through the tuner.   Or has 20m prop just been bad for the last few days?
   You input would be appreciated.
Scott E. Fields, K8AEC
« Last Edit: June 21, 2012, 06:42:37 AM by K8AEC » Logged
N4ATS
« Reply #1 on: June 21, 2012, 07:41:35 AM »
If you download the service manual for the FT-450 (its free all over the place, just google it) you will see on the IF board , near J-2001 , 2 protection diodes D2001 and D2002 , you probably shorted them out with front end harmonic overload. Then if that does not fix it , replace the FET preamps
First thng to do is throw out the MFJ switchbox (worthless) , get an Alpha Delta...
« Last Edit: June 21, 2012, 07:48:59 AM by N4ATS » Logged
K8AEC
« Reply #2 on: June 22, 2012, 08:35:13 AM »
So even though the rig was not powered on and bypassed by the switchbox it can be damaged?
Wow...that stinks.
N4ATS
« Reply #3 on: June 23, 2012, 04:58:41 AM »
You bet , what kind of switchbox do you have? MFJ?
KA4POL
« Reply #4 on: June 23, 2012, 10:11:37 PM »
How do you think your microwave works? Put a diode inside and switch it on. You'll do that at your own risk  Grin
K7KBN
« Reply #5 on: June 24, 2012, 04:25:16 PM »
Wow...that stinks.
Obviously, it wasn't bypassed all that much.  N4ATS gave you good info regarding your switchbox.
« Last Edit: June 24, 2012, 04:26:52 PM by K7KBN » Logged
Pat K7KBN
CWO4 USNR Ret.
K8AEC
« Reply #6 on: June 27, 2012, 06:27:24 AM »
Thanks so much for the info.
Took the radio to field day and put it on the meter; as expected, the diodes were dead.
It's only going to be a $40 repair, so lesson learned.
And the switch box is an old, unlabeled one.   A CB throw-back.
Needless to say, I won't be using it anymore.
Again, thanks SO much for the correct info.
N4ATS
« Reply #7 on: June 27, 2012, 04:56:32 PM »
Anytime....
K8AEC
« Reply #8 on: October 28, 2012, 10:50:33 AM »
Update:
The protection diodes were in fact blown.   However, replacement of the diodes did not fix the problem.
The radio was returned to Yaesu for a warrenty repair.
It turns out that the finals were blown...I was shocked.
I can only assume that there was a defect.
The radio is back in the shack and working flawlessly; as a matter of fact I just hit the 100 DXCC mark yesterday.
I'm going to add a TenTec 715 speech processor soon as I don't have the cash for a proper amp...none of that RM Italy crap.
Thanks for all the Elmer advice.
K8AEC
