Author Topic: Any ohio hams interested  (Read 8520 times)
KD8DEY
« on: June 22, 2012, 06:14:56 PM »
In a copy of the OARC 2012-2013 repeater list converted into a
spreadsheet? would make it easier to import into your programming
software to update your rigs.
KD8DEY
« Reply #1 on: June 23, 2012, 06:17:43 AM »
Almost 100 views and no takers.
Guess not
KE5JPP
« Reply #2 on: June 23, 2012, 07:51:13 AM »
Guess not
I imagine most guys who'd want a spreadsheet could import the list themselves.
Gene
KD8DEY
« Reply #3 on: June 23, 2012, 09:40:21 AM »
Guess not
Gene
Over 800 entries covering all 5 Ohio districts from a PDF file of the 2012-2013 Ohio Amateur Repeater Council
Directory?  (Ohio's coordinating body)
http://www.oarc.com
Not normally available Anywhere as a spreadsheet.
not a simple "Import"
sortable by District, County, Frequency, Callsign..............Exportable to be able to Import into Rig programming software..............
KD8DEY
« Reply #4 on: June 24, 2012, 12:28:18 AM »
PS
No Im not trying to "sell" it.
just thought somebody might find it of use....
KB9BVN
« Reply #5 on: June 25, 2012, 12:25:15 PM »
KD8DEY...I guess this is living proof that no good deed goes unpunished. <grin>
KE5JPP
« Reply #6 on: June 26, 2012, 03:53:17 AM »
No, it is only proof that currently no one reading this on eHam is interested, that's all.  I'd be interested if I lived in Ohio.
Gene
KG4RUL
« Reply #7 on: June 26, 2012, 05:44:49 AM »
Take the total number of licensed Hams in Ohio - Subtract the number who are active at all - subtract the number who do not use repeaters - subtract the number who do not use eHam.   What you are left with is your target audience.  It may be substantial OR more likely a number that you can count on your fingers without repeating.  Then subtract the number who feel the need for an extensive repeater listing.  At that point you may have zero.
W5DQ
« Reply #8 on: June 26, 2012, 05:26:45 PM »
Guess not
Would not do me any good as I am not in OH. But I did view the post. Sorry to throw your numbers askew Smiley
Gene W5DQ
Gene W5DQ
Ridgecrest, CA - DM15dp
www.radioroom.org
KB8TVN
« Reply #9 on: July 09, 2012, 12:59:27 PM »
I may be a little late but I'm in Ohio and would be interested if it's a freebie. Probably it would be good to have available both in spreadsheet and PDF on the website, wouldn't it?
KD8DEY
« Reply #10 on: July 09, 2012, 05:52:52 PM »
Still available. I see that you are not far from me in Troy.
KD8GEH
« Reply #11 on: July 11, 2012, 12:27:55 PM »
Count me in, 2 coutem 2 takers. Grin
73, Dave KD8GEH at arrl dot net
KD8DEY
« Reply #12 on: July 11, 2012, 02:01:11 PM »
still need an address to send it to........
