Author Topic: Embarrassingly Simple Antenna Question...  (Read 2682 times)
KW6CSS
« on: July 03, 2012, 01:27:30 PM »
Hello All,
This will probably seem like a really simple question, but here goes...
I have been a "listener" for years, and have a nice Alpha-Delta DX dipole hooked up to my Drake receiver and it works great.  I am just now getting my first transmitter, an old Heathkit DX-60.
My problem is that I would like to use the same antenna on both radios simultaneously.  Is that a possibility?  I don't want to fry my receiver when I transmit...
I'm sure this can work, but I'm not quite sure how.  I've seen plenty of switches which let you use multiple antennas on the same rig, one at a time, but not this.
Any help is appreciated!  Thanks-
Mike KI6BXK
W4VR
« Reply #1 on: July 03, 2012, 01:58:42 PM »
Several manufacturers make a device to switch your antenna between transmitter and receiver.  MFJ sells an RF-sensing T/R switch (Model 1708) that allows you to receive on the antenna and when you transmit it senses the RF and connects your antenna to your transmitter.  I believe it costs around $80.
KW6CSS
« Reply #2 on: July 03, 2012, 02:12:14 PM »
Thanks! The 1708 looks perfect...  I'm not sure how I missed that, since I look at my MFJ catalog on a daily basis.
I'd much rather invest in that than put up a 2nd antenna.  (Especially since the DX-60 may or may not completely work...)
Thanks for the reply to the rookie question that I really should know... Smiley
KB2WIG
« Reply #3 on: July 03, 2012, 02:13:52 PM »
Embarrassingly simple question..... do you have the manual fer the dixie sixty?
http://www.mods.dk/manual.php?brand=heathkit
" use the same antenna on both radios simultaneously.  Is that a possibility? "
The simple answer is  ~Yes You Can~
But you want to switch the antenna between yer Drake and the '60.
What kinda Drake??
klc
AD5X
« Reply #4 on: July 03, 2012, 02:17:10 PM »
Look at the "Boat Anchor T/R Switch" in the "Articles" section of my website at www.ad5x.com.  Simple, cheap, and works well.
Phil - AD5X
KW6CSS
« Reply #5 on: July 03, 2012, 02:27:03 PM »
I MAY be getting the manual too...  The guy I'm getting it from may or may not be able to find it.  Fingers crossed... I'll drop you a line if I have success- It might "inadvertantly" fall onto a copy machine somehow...
As for the Drake, it's an old SW1 that works great.  I am going to need to have both hooked up and working on the antenna at the same time in order to carry on a communication with anyone, since I would like to hear both sides of my conversation... Smiley
I'm thinking that MFJ-1708 may be perfect for me.
« Reply #6 on: July 03, 2012, 02:55:58 PM »
If you want to keep it true to the vintage of a DX-60, find a dow key relay.  I've seen them for as little as $5 at hamfests.
KA4POL
« Reply #7 on: July 03, 2012, 10:04:43 PM »
See http://www.amwindow.org/tech/htm/dx60ptt.htm
If you need help forthe DX-60 there is a very supportive Yahoo group: http://groups.yahoo.com/group/heathkit/?yguid=55990539
K4SAV
« Reply #8 on: July 04, 2012, 08:48:29 AM »
You probably already know this, but just in case, the DX-60 is crystal controlled.  You will need a VFO or some crystals.
