Author Topic: NO WATERFALL DISPLAY-FLDIGI  (Read 9341 times)
W6PJJ
« on: July 15, 2012, 04:09:25 PM »
I have encountered a situation with FLDIGI. I have been running PSK31 for several months now with FLDIGI running on an iMac. But, two days ago I suddenly noticed that the Waterfall was no longer being displayed in the Waterfall area of my monitor. I am able to copy stations when I place the cursor over a readout in the Signal Browser Field though, so I know it's not the lack of audio. I already put the interface on the bench and it tested our OK!. I have consulted the helps and gone to the FLDGI helps on-line but for the life of me I cannot find out why the display has disappeared. I suspect that I may have accidentally pressed some Key combination and caused it to be turned off.  If by chance maybe someone on eHam may have the answer to this dilemma.  ??  Undecided
KK4CPH
« Reply #1 on: July 15, 2012, 07:33:59 PM »
I've had this happen to ma a few times on my Mac.  I don't know what causes it but I just exit FLdigi and restart.  Sorry not much help.  Must be one of those "Mac" things.   Huh
Eric
W6PJJ
« Reply #2 on: July 15, 2012, 09:54:09 PM »
Thanks for the reply... I gave the Mac the Old Boot several times but still no change. I do not recall making any changes to the program parameters or settings so this is real brain twister. I may eventually reinstall the Application... it may have been corrupted. TNX AGN,
Don-W6PJJ Cool
« Last Edit: July 15, 2012, 09:55:48 PM by W6PJJ » Logged
KB5JOF
« Reply #3 on: July 16, 2012, 07:37:21 AM »
Check the "VIEW" menue.  I run Flidigi in Lenux and have noticed there are two places to turn the waterfall off and on.  One is under configuration and the other in view.
Joe
KB5YOA
K3DCW
« Reply #4 on: July 16, 2012, 07:35:10 PM »
W6PJJ,
Have you got this resolved yet?  I sent you some suggestions on the other site where you posted this same message.
Check there for my input, along with that of a couple of others.
Dave
K3DCW
Hamming it up on OS X!
www.machamradio.com
KK6ZTI
« Reply #5 on: August 13, 2016, 10:43:47 PM »
I know this thread is from a few years back however tons of HAMs still have this problem, including me; until about an hour ago.
The only sound card that never gave me a dead waterfall in fldigi and wsjtx is the one built into my Allen & Heath ZED 10fx mixer.  It's an awesome mixer for HAMs, surprised it's rather unheard of to them; but even so, it's not viable for my music production work and space is limited in the home studio.  Thus I went down the rabbit hole of trying to get my RME Fireface UFX working with these apps in El Capitan, which I know now is impossible.  Even if you can put a sound card into an OS X class compliant mode there's a good chance it will still deliver a dead waterfall.
Sure would have been nice if the fldigi developers could have solved this problem but it's moot at this point if you use Loopback: a $99 app that easily lets you route the software playback audio output of any app to another.  This is the only truly dependable working solution as of now.
https://rogueamoeba.com/loopback/
