Author Topic: Measuring SWR on Diamond MR77 with 2M HT  (Read 3427 times)
N4NYY
« on: August 10, 2012, 09:37:32 AM »
I am about to purchase a Diamond MR77 so I can use my FT-60 in the car. Must be a magmount because I frequent parking garages for work. Anyway, I have a Diamond SX-200 SWR meter that will measure 2M, but not 440.
Since this is my first voyage into mobile 2M and measuring SWR on 2M, can I simply measure the SWR in FM mode? I have only done it in HF up til now on AM.
KA4POL
« Reply #1 on: August 10, 2012, 10:34:40 AM »
No problem, yes, you can.
N4NYY
« Reply #2 on: August 10, 2012, 02:03:04 PM »
This is like my first trip into VHF land. I went on a fox hunt last Sunday. I am starting to like it.
KA4POL
« Reply #3 on: August 10, 2012, 09:54:17 PM »
This may just be the beginning. All of a sudden antennas are getting handy. And at 10 GHz and above you may need a course in plumbing.
K6LCS
« Reply #4 on: August 12, 2012, 09:48:43 AM »
Why do you want to measure SWR with an HT and a mag mount antenna?
If the antenna is new - and there is no squished or kinked cable - then just use it.
Clint K6LCS
Clint Bradford, K6LCS
http://www.work-sat.com
N4NYY
« Reply #5 on: August 12, 2012, 10:27:48 AM »
Clint K6LCS
From Diamond's installation instructions: http://www.diamondantenna.net/pdfdocs/MR77.pdf
3. Install antenna on vehicle. With a quality VSWR meter, check VSWR. The MR77 and MR77SMA are pre-tuned, and should require no adjustment.
IOW, just check to be sure.
KA4POL
« Reply #6 on: August 12, 2012, 10:41:43 AM »
Much better than finding out the hard way  Cheesy
K6LCS
« Reply #7 on: August 12, 2012, 12:11:28 PM »
OK. Check SWR on everything you do.
The original poster has a 4-5W HT, and a good quality mag mount that is already tuned for best performance on 2M and 440. Personally - and if the antenna is new - I wouldn't drag out a SWR meter to the car to test it. My resulting signal reports will let me know how well my 4-5W are hitting local stations/repeaters.
Change the equation, though, with different radio and/or antenna, then my answer might be different ... (grin)
Clint K6LCS
N4NYY
« Reply #8 on: August 12, 2012, 01:47:30 PM »
Clint K6LCS
I do not understand what you are saying. Are you saying that if it were the case that the SWR were high because of a defect or something, that it would not do damage do the HT because it is 5W?
I am using a 5W HT as of now. Will likely go to a higher wattage mobile later. Still, for the time it takes to check SWR, it is kind of lazy to NOT check it, just because it is new. And please do not tell me that you have never gotten anything new, that did not work out of the box, ever in you life.
K1WJ
« Reply #9 on: August 23, 2012, 11:39:41 AM »
Modes to test swr: FM,AM,CW. I have MR77 - works good for me. 73 K1WJ David
AB0RE
« Reply #10 on: August 23, 2012, 04:38:08 PM »
I think what Clint is saying is that you'd be surprised (and not in a good way) to see what the SWR is on most rubber duck antennas.  It's nothing for them to see a 3:1 SWR regularly (it varies wildly depending on where you are when you transmit) and the HT does fine.  In other words, it'd be good advice to check the SWR, but if you're TX/RX signals are okay you can bet the SWR is no worse than what your HT has seen via the rubber duck antenna.
K1CJS
« Reply #11 on: August 24, 2012, 04:27:51 AM »
I do not understand what you are saying. Are you saying that if it were the case that the SWR were high because of a defect or something, that it would not do damage do the HT because it is 5W? ...
If you actually looked at the SWR of the rubber duckie antenna that came with your HT, you would more than likely get a shock--it would probably be sky high.  Most rubber duckie antennas are little better than dummy loads.
The importance of low SWR is just about always overblown.  It is nice to get that SWR low, but you don't have to get it way down to 1.1 to 1--it probably wouldn't be possible anyway.  Anything below a 2 to 1 SWR reading is good.  It's when you have readings of 3 to 1 or higher that your rig may have problems.
KA4POL
« Reply #12 on: August 24, 2012, 08:12:01 AM »
Unbelievable! To my experience dummy loads are much better than rubber duckies. I mean real dummy loads.
K1CJS
« Reply #13 on: August 28, 2012, 06:22:41 AM »
....I mean real dummy loads.
You're right!  And it isn't because it's hard (impossible) to put an RF connector on those 'real' dummy loads either!   Grin
KD4EBL
« Reply #14 on: August 28, 2012, 09:20:52 AM »
I think it is a good idea to check SWR yearly or when you think there is a problem and write down the results. That way you can compare it to the last time you checked it. When I first got my mag mount, I checked it after moving the mag mount several places on the roof and trunk to see where I would get the best results. Intresting how the result would change, even by moving the antenna a couple of inches. I also check all my rubber duck antennas to see how they fair and get rid of them if they start to go south.
