Is there a diagram on installing 2 meter mobile in 99 Ford Explorer or similar
Martin G. (Marty) Blaise:
I have been looking on the internet for a diagram on how to install a two meter mobile radio for a 99 Ford Explorer. I have a Yaesu 2-meter mobile that I'd like to install in the vehicle.
Dennis Zabawa:
I doubt that you will find such a diagram. The variations on an install can be significant from vehicle to vehicle even in the same model and year. Trim level and options can vary. Even the differences between a stick or automatic factor in. Your choice of antennas and mounts along with the specific radio you choose can add more variation.
I would start by choosing antenna and mount along with your chosen radio and get them in-hand. Figure out where you will mount the radio and microphone taking in the need for ventilation for the radio, your need to access the radio controls and view the display and a location for the mike that will be easily accessible while operating the vehicle.
Depending on your skill level, the type of antenna mount and the tools you have available, you may want to take your vehicle to a stereo installation shop or radio shop to mount the antenna and run cables. If these operations are within your capabilities, consider cable routing, protecting cables from sharp edges and, in the case of a through metal mount, how you will locate and drill the mounting holes.
Additionally, you may have RF noise problems from the engine and on-board computers or may in fact cause interference to these systems.
A challenge but, doable with a little patience.
BILL MERRITT:
Just do it. It isn't rocket science, no one is going to hold your hand.
Chewing gum, velcro, Cherry rivets, nails and plywood....whatever.
It's just a car that will be razor blades in 15 years.
**Please don't take my rant personally**
It's just that I don't understand why we have people asking the same question endlessly every week. There is no magic formula. The internet has endless examples of how to do an install.
Speaking of which, please check out Alans' Gem: http://www.k0bg.com/
Everything you wanted to know about mobile installs. Everything.
Don't be afraid to jump in and do something. You may change your mind for a better way in a month but that is ok. GL, Bill
Eric Watson:
If you are afraid or unable to do an install yourself, find the local radio shop that does installs for public safety vehicles. I have taken three vehicles in over the years to have power run from the battery through the firewall to a radio. They also have all the tools for installing NMO mounts properly. Expect to pay for this service but it will be professionally done and worth it.
A radio install shop should be able to run power/antenna in a Ford Explorer with their eyes closed.
Alternately, find the guy in the club who knows how to do this and ask him to help you do your install. He probably has the tools and so you would just need the materials. Expect to buy him a case of beer and a pizza. Then you will know how to do an install the next time, from experience.
Or wing it. The burned hand teaches best. Make sure you have another vehicle available to take to the auto parts store if you drill through the firewall into your water pump or heater core (hi hi).
Good Luck,
Eric, K0ECW
Mark Duncan:
Talk to Dwayne At Riveroaks car stereo, he and the owner are hams. they should be able to"hook" you up.
Navigation
[0] Message Index
[#] Next page
