Author Topic: amp quesrion  (Read 979 times)
N1BIL
« on: August 21, 2012, 11:32:35 AM »
I have a Yeasu FT-450 and want to know what amps will not work with the rig and why? Are there any recommended amps for this rig?
K7KBN
« Reply #1 on: August 21, 2012, 11:46:52 AM »
I don't know of ANY amplifier that will work with a "Yeasu".
Pat K7KBN
CWO4 USNR Ret.
VE3FMC
« Reply #2 on: August 21, 2012, 12:10:15 PM »
Any HF amp should work with the FT-450. However you need to make sure that the keying relay voltage is low enough for the radio to handle.
Most of the older amps, such as a Heathkit SB-200 or SB-220 have higher relay voltages than the radio will be able to handle.
Now that is not a big problem as long as you use a keying relay between the rig and the amp. Or in the case of the Heathkit amps you can do the Harbach mod that lowers the keying voltage to a level that modern rigs can handle.
I have used an older SB-200 with my FT-950 but the amp had the Harbach keying relay mod done to it.
KA4POL
« Reply #3 on: August 21, 2012, 09:48:36 PM »
The FT-450 is a HF/6m rig with 100 watts, 25 watts AM output. If you check your manual you'll find this in the specs. Exactly these are the limiting conditions for your amplifier. It got to be able to handle this. Any amplifier outside these data will not be usable. As a sample, any 144 MHz amp will not help you.
KB3HG
« Reply #4 on: August 23, 2012, 09:07:19 AM »
Real simple, look in the manual should show you the way Yeasu connects to an amplifier. At leas the two manuals of different Yaesu HF radios that I have do. It should have a interface that you hook up between the radio and amp. Google it, you will get more information than you want and specific to your model.  Enjoy
Tom Kb3hg
KG4NEL
« Reply #5 on: August 23, 2012, 09:53:20 AM »
C'mon, you've never fat-fingered while typing?  Tongue Rough crowd...
'VSG - what kind of operating do you do, mostly? Amp selection depends on factors like:
- Do you need 160m? Not every amp covers Top Band.
- Do you operate CW, and need QSK?
- 120VAC or 220VAC to the shack? Not having 220 will limit your selections.
« Reply #6 on: August 23, 2012, 12:07:46 PM »
If you get an external, like I think it is a MFJ 704  keying relay, you can use it for any amp.  this hooks up on the amp keying output ( also call keying or linear relay) on the radio, and it isolates the rely line from the amp back to the radio, regardless of parameters.
K7KBN
« Reply #7 on: August 23, 2012, 02:07:52 PM »
Once in a while.
But I CAN read the word "YAESU" off the front of the radio.  It doesn't say "YEASU".
Pat K7KBN
CWO4 USNR Ret.
KB1LKR
« Reply #8 on: August 23, 2012, 05:25:24 PM »
But I have to look at the keys when I type Sad
« Reply #9 on: August 24, 2012, 05:38:56 PM »
If I had a Yeasu I think I'd use it with a diploe antenna.
Both seem to be popular on eHam.
 Grin
