Pages: [1] 2 3 Next   Go Down
Author Topic: K2 as main DX/contest rig?  (Read 2914 times)
K3STX
« on: August 23, 2012, 07:30:19 AM »
My Kenwood TS-850S is getting pretty old, I am thinking about a new rig. I am 60% DXer/40% contester. I only operate CW. Is a K2 or K2/100 a reasonable replacement for the TS-850S? It certainly is cheaper than lots of the new rigs and I am on a somewhat limited budget. A K3 or TS-590S might be nice (and more expensive), but with those rigs I am paying for SSB capability that I do not want. Another bonus of K2 is I can bring it with me on trips.
Any TS-850S users switch to a K2? NOT a K3 (I am too poor), but specifically a K2.
paul
KA5N
« Reply #1 on: August 23, 2012, 08:00:32 AM »
It is interesting to note that on the recent D64K dxpedition they used Elecraft K3's for
SSB operations and Elecraft K2's for CW.  The K2 is an excellent CW rig (and not bad at all
for SSB if you go that route). The K2 is easy to operate.  The 100 watt output is plenty
for most uses and if your only rig it will do most everything you need.  Of course it doesn't
have 6 meters nor 30 meters (I don't think the  TS 850 does either).  Of course if you buy one
new you have to put it together (there are expert assemblers available at low cost or a good
used one is a good deal) but after building one you find it is easy to repair (I had to replace
the 10 watts transistors that somehow got wet and shorted out).
Go for it!!!
Good Luck   Allen KA5N
« Last Edit: August 23, 2012, 08:15:06 AM by KA5N » Logged
K3STX
« Reply #2 on: August 23, 2012, 08:28:20 AM »
Thanks, Allen. Building it is one of the main reasons I am interested in it. I do NOT like the fact that it is a tiny radio, but almost all of them out there are tiny radios. It DOES cover 30 meters. I would get 160 meter/RX antenna for it. I would probably not go 100 watts for now, I bet that 12 watts output could drive my AL-811 to put out 200 watts or so.
paul
NU1O
« Reply #3 on: August 23, 2012, 09:30:55 AM »
paul
I see a few problems. My K3 is a very small radio, much smaller than I wanted to buy, but with ham neighbors encircling me and with one who is in range of a good golf shot with a 3-wood, once I read the article in QST that the blocking dynamic range was the best the ARRL lab had ever tested that was all I needed to know and let's just say I tolerate its small size.  I also ran into Bob Sherwood on the air one day and he said based on his tests the K3 was the best receiver on the market.
However, if the K2 is smaller than the K3, and I think it is, you are dealing with a really small radio. That might have changed my choice were I buying a K2. I don't know why you say MOST are small radios. My choice was between this K3 and an Icom 756 Pro 3 and that was massive compared to the K3. Even the lower priced Kenwood and Yaesu rigs look a good deal larger than my K3.
I agree about building your own equipment although it's not a kit in the tradition of Heathkit since there is no soldering. You are just using nuts and bolts, unless you need to make a modification or upgrade and actually replace a part. Then you need to take out your soldering iron. I call it "assembling" rather "building" bit it will familiarize you with the different circuits and make repairing easier provided you know how to troubleshoot bad parts to begin with.
I do contest but it's not a passion for me like DX. From what I understand of contests once you are over 100 Watts you're classified as High Power. You'd be better off shutting the amplifier and running in the Low Power category because 200 Watts will not be competitive when most guys in the HP category are running the maximum of 1500 Watts. That's what I run when the contest allows for it.
If you can afford to do so stay away from second-hand gear. You are usually buying somebody's problems no matter what reason they give you for selling. That's my experience anyway.
Good luck making your decision. I'm in the process of going through the exact process but I'm selecting a new antenna(s), rotor, and mast. I would've liked to ask the question in this forum since I don't know the people in the antenna forum but I deemed it out of bounds.
I don't know what I'd do without the help of our forum member, W6GX, Jonathan. He owns the Bencher Skyhawk I'm going to buy and he has been most generous with email and phone help. He's a real gentleman and he's been patiently answering all my questions.
My A3S just blew the 3rd trap in one year since buying my Alpha 8410. Cushcraft rates the A3S at either 2 Kw or 1.5 Kw but it's just marketing baloney from MF Junk. Those traps are as cheap as they come and the wire very thin. It's time to replace it before the weather gets cold here in New England.
Chris/NU1O
« Last Edit: August 23, 2012, 09:48:32 AM by NU1O » Logged
K3STX
« Reply #4 on: August 23, 2012, 10:44:59 AM »
The K2 is a you-solder-it kit, the K3 is assembled. And I DO know it is small. My TS-850S is a manly sized radio, as are FT-1000s. But many "new" radios are smallish, the Pro III is an 8 year old radio. But I want a better RX and need a "new" radio for less than $1K.
As a CW op the only knobs I really use are tuning, RF gain, and which IF filter to have in-line. I rarely even use notch, I just use my brains notch filter.
p
NU4B
« Reply #5 on: August 23, 2012, 11:01:24 AM »
I have a K2  - it is a great CW rig. I don't have the SSB option installed, but do have it in case I want it. I don't have a K3 , but my best buddy does and it is a very nice rig. I had shelved my K2 for several years - then when I finished it the K3 came out shortly thereafter.
If price is a concern go with the K2. If you want to build it piece by piece go with the K2. It is a great build and as you probably know support is excellent both from the company and the support group. (I had a question about a new firmware install. I asked the support group on a Sunday evening and had the answer in a couple hours.)
I have all the other options installed on the K2. Another thing I like is I can take it anywhere and operate and everything is there including battery in one package. If that's important get the K2.
If price, build, and/or ease of portability are not concerns - get the K3. They aren't going on all these DXpeditions because there's extra space. As Chris, NU1O, noted you can still build your K3 - its just in modular form.
By the way about 10 years or so ago a team of ops took K2's to Jamaica and operated SBQRP (on just about all the bands) in the CQWWCW contest. I think several of them still hold world records (and/or NA records) on the bands they operated.
NI0C
« Reply #6 on: August 23, 2012, 11:03:19 AM »
Paul,
I used a TS-850S for about eight years, and now have the K2/10, as well as the K3.  I think the K2 would be an excellent replacement for the TS-850S.  I have the DSP audio filter, as well as the 160m kit in my K2.  I use the K3 most of the time, but do enjoy the K2 during QRP events.
My son still has my old TS-850S, and it is has been used for Field Day by the K9YA group for several years.  Everybody loves the 850. I keep waiting for the lithium battery to crap out, but it's still going strong.
Chuck  NI0C
K3STX
« Reply #7 on: August 23, 2012, 11:25:11 AM »
Thanks. I had my battery replaced on my 850S about 3 years ago, so all good there:) As NU4B noted, one of the reasons I am interested in the K2 is I DO bring my small QRP radio with me on business trips (a Small Wonder Labs SW40+), but monoband and 2 watts doesn't always cut it. 12 watts and the ability to use a different band would be nice.
I know the K3 is a "better" rig, but it will cost me more than twice the cost of a K2 and I don't need most of the features.
p
NU1O
« Reply #8 on: August 23, 2012, 04:14:27 PM »
p
I thought the K2 was just hardware assembly like the K3. I don't think you have really much choice but the K2 given the financial constraints you set. If the K2 has anywhere near the receiver the K3 has (and I know it's good, just not how good) I can't see where you are going to find another rig for less than a grand that will work with all that QRM a contest generates. I have the 250 Hz CW filter in my K3 and it's terrific for DXing or Contesting. I probably run it too narrow as in general use I often find guys outside my passband. Either they don't know how to properly zero beat or they are running old rigs.
You know it's very small and you are prepared to do the soldering. Seems like all that's left is to pull out your credit card and order it.
Chris/NU1O
NI0C
« Reply #9 on: August 23, 2012, 06:11:14 PM »
The K2 is a fun assembly project, and the K2 gives good performance for its size.  I just checked its ranking in the Sherwood Engineering tables, and it has dropped behind some of the newer rigs, but still has very respectable specs: http://www.sherweng.com/table.html
If you're going to be adding any options at all to your K2 (especially the DSP filter or noise blanker), you should be aware of the "Rework Eliminators" designed to make adding the options easier.  See the eHam reviews at: http://www.eham.net/reviews/detail/6372?page=2
or the company website at: http://www.unpcbs.com/headers/
(I'm not affiliated with the company in any way, except that I wrote the first eHam review for their modules several years ago, after building my K2.)
Feel free to e-mail me if you have any questions about the K2.
Chuck  NI0C
K3STX
« Reply #10 on: August 23, 2012, 08:38:37 PM »
Thanks for the info on the Rework Eliminators, I never heard of that.
But the numbers on that new KX-3 are amazing!!! And only $150 more than the K2 kit AND includes 160M and Dual Watch. But talk about tiny!!!
P
NI0C
« Reply #11 on: August 24, 2012, 05:00:05 AM »
I don't know why I didn't think of the KX3 in this discussion.  One CW feature I think it has is APF-- very useful on my K3 for peaking weak DX signals.  As far as building is concerned, the kit is "modular," like the K3 kit.  I think the only thing I soldered on the K3 was the power cord, and even for that they suggested using a crimp tool (Anderson power poles).
If you haven't already done so, be sure to look at archives of the Elecraft Reflector to see what people have been saying about their new KX3's.  Elecraft has announced their products will increase in price slightly, beginning in mid-September.
Chuck  NI0C
KY6R
« Reply #12 on: August 24, 2012, 05:32:37 AM »
Unless you really want to solder, I'd get the KX3 . . . . .
N4OGW
« Reply #13 on: August 24, 2012, 06:20:36 AM »
I used two K2's for several years as my main radios, mostly for contest operating. Since then I had upgraded to K3's, although I still have one K2 for backup/portable operation. I originally used one K2 along with an Omni VI. I found that the K2 receiver was better than the Omni, so I sold the Omni to buy a second K2. The K2 receiver is almost as good as the K3, but the K3 does a little better in crowded bands.
Yes, the controls on the K2 are small. I pretty much got used to that however. For contest operation you can control many of the functions from a computer anyway. Some other considerations:
-if buying a K2, I wouldn't bother with the audio DSP. The buttons controlling it are so hard to use during a contest that I basically just left it on one setting continuously to reduce hiss. The cheaper audio filter is just as good for this.
-There is one "feature" of the K2 firmware that is really inconvenient for contest operation, especially SO2R where you change bands a lot: after a band change, the RF output power is always increased from zero (presumably to protect the finals). After a band change the RF power starts at zero and slowly comes up to whatever it is set to over a second or two. It is slow enough to make the first letter or two on CW inaudible to other stations. The result is that my call at ~35 WPM comes out as "...UOGW". In practice you have to be sure to press "tune" for a second or so (transmitting a carrier) after every band change. I can't think of the number of ?'s I got in response to calling stations due to this.
I didn't find the K2 hard to build (I built 2), but it does take a lot more time than a K3.
The KX3 looks good, but be prepared to be QRP for a while- there is no 100W amp available yet.
Tor
N4OGW
N5MOA
« Reply #14 on: August 24, 2012, 06:30:18 AM »
P
It's bigger than the control head on my TS-480, Paul.
73, Tom
Pages: [1] 2 3 Next   Go Up
