Author Topic: YAESU FT 2900R  (Read 1670 times)
KB3ZBE
« on: August 26, 2012, 12:54:41 PM »
I wasn't sure where to ask this question, but I figured since this
is normally used as a mobile unit I'd start here.
This looks like a good 2 meter radio based on reviews on the
site especially considering it's available for about $160. However,
I plan to use it in my shack as one of my base units.  My
issue is that Yaesu's power supply (for AC) cost about as
much as the radio!
I'm a relitively new Ham, so I figure there muct be a cheaper
way to go.  You experienced guys out there I'm sure have
some ideas.
Any suggestions?
Mike
KB7FSC
« Reply #1 on: August 26, 2012, 06:01:16 PM »
Hi Mike,
What are you currently using for a power supply in your shack?  Are you just beginning to build up your shack?
I am using an Astron RS-35M to power multiple radios in my shack (including a FT 2900R).  Thats the good part about having only one mouth and two ears.  I figure I can only talk on one radio at a time anyway, so one power supply, many radios.  Grin
Wane
KB7FSC
KB1LKR
« Reply #2 on: August 26, 2012, 07:23:29 PM »
Almost any 13.8 VDC nominal power source should do.
An Astron RS-35 linear power supply would be ideal, a RS-20 also would work for a VHF-FM rig but could be marginal for many other future applications (e.g. any 100W+ HF rig).
See also Alinco, Astron, Samlex and other switching power supplies capable of 25 A *continuous* if weight and size are important issues (They likely are not for base use however).
KB3ZBE
« Reply #3 on: August 26, 2012, 07:30:21 PM »
Thanks for the reply Wane.
Yes, I'm getting my shack organized -- I've only had my license
for about a month but I've been working on the shack for some time.
My main rig for transmit / receive is an ICOM 756 PRO III.  It
has it's own power supply that has one output and a connector
with a 6 prong cable.  My ICOM receiver that I use for SWL
has it's own power supply as well.  Both use 13.8 DV volts.
An aftermarket supply like the Astron you mention might be a
good way for me to go for future uses.  I'll check it out.
Mike
KB3ZBE
« Reply #4 on: August 26, 2012, 07:47:33 PM »
Thanks for the reply Steve.  I Checked out the prices on the
Astron PS's you mentioned.  Guess there is really no "cheaper"
way out here, especially if I go for the R35 model.  However,
it might make more sense for other future uses.
Mike
W8EDV
« Reply #5 on: August 27, 2012, 04:09:08 AM »
You can pick up a 13.8 volt   36 amp power supply,   " Mega Watt"  brand on Ebay for $67  and I believe  free shipping.  They run 30 amps continuous 24/7 if you needed to do so.   From my reading on these they are very good I might get one to replace my old Astron 20 amp supply. For that money they are a good deal.
W9MMS
« Reply #6 on: August 27, 2012, 06:33:05 AM »
Mike.
There is a very distinctive difference between "CHEAP" and being "FRUGAL"!
There are Tons of Info here on the various Forum. I would suggest you take some time to read, read and read again
before you go handing over your hard earn cash.
Ever hear the old adage " You get what you pay for "
I can understand you having a real shinny new Ticket, with a couple of pennies in your pocket.
We all have been there, yours truly included, but hold onto those pennies for a little bit longer while
you get a little better hang of things.
I refrain from telling you what to get in terms of equipment. I'll strongly suggest you do your research.
HAPPY TRAILS, and Congrats on getting your Ticket!
(((73))) Milverton.
KB7FSC
« Reply #7 on: August 27, 2012, 08:44:48 AM »
Hi Mike,
Congratulations on your new license!  With your next upgrade to General, you will be able to really start getting your money's worth out of your fine station.
I went with a smaller, older power supply when I set up my station a couple years ago, trying to work on "the cheap".  My solution worked, but it became apparent to me that I really needed a decent power source, and I haven't regretted my Astron power supply.  It was a good lesson learned for me.
Enjoy the hobby, and hopefully I'll meet you on the air one of these days!
Wane - KB7FSC
KB1LKR
« Reply #8 on: August 28, 2012, 06:31:29 AM »
Not as convenient, but you could adapt from the 6 pin HF P/S connector to the 2 blade 2900 connector or put Powerpoles on the 2900.
http://www.powerwerx.com/adapter-cables/  etc.
