Author Topic: New whine in Received and transmitted audio...alternator going bad?  (Read 3696 times)
« Reply #15 on: September 07, 2012, 11:23:28 AM »
It depends on car make/model but a really doubt it is a ground. If it was a ground issue it would not of suddenly appeared after many years  and would be likely intermittent too. You could spend a lot of time chasing gremlins looking for ground issues. You mentioned it is a older car. Swap out alternator with a rebuilt one.
KB9WQJ
« Reply #16 on: September 07, 2012, 11:50:17 AM »
  It's a 2005 Ford Focus.  I have a longish commute and got tired of feeding the truck...it's a gas-sipping commuter car.
« Reply #17 on: September 07, 2012, 11:55:07 AM »
7 years is a good long service life in todays cars that place far higher demands on alternator than cars 25 to 35 years ago.
KI4SDY
« Reply #18 on: September 07, 2012, 05:19:47 PM »
It is not going to cost you anything to check the ground contacts first, before you run out and buy a rebuilt alternator. We are running two Ford vehicles that are over ten years old and do not have a whine problem at this point.  Grin
If that doesn't fix it, then the alternator is probably going to have to be replaced.  Cry
« Last Edit: September 07, 2012, 05:23:12 PM by KI4SDY » Logged
KI4SDY
« Reply #19 on: September 07, 2012, 07:46:25 PM »
How did disconnecting the antenna work for you? Did you still hear the whine?  Huh
« Reply #20 on: September 07, 2012, 08:23:40 PM »
Nothing but time and hassle chasing gremlins. I have seen alternators last 10+ years and I have seen them fail in 3 years too. 5 to 7 years is about average.
« Reply #21 on: September 07, 2012, 08:33:31 PM »
Is there a list of them somewhere?
The grounds you're looking for are not that many, and not hard to locate.
The way I do it is to run the engine and turn on some loads, like the heater fan on high with the headlights and rear window defroster on.  Then I use a digital voltmeter with one probe on the negative battery terminal and start touching the other probe to different parts of the engine and chassis.  With good bonding, you should never see any voltage difference at all, maybe a tenth of a volt at most.  When a ground is compromised, you may see upwards of a volt or more.  This is usually accompanied by other symptoms like lights that brighten and dim, radio memories that reset, blowing bulbs, and other untold anomalies.
When you drive cars old enough to vote, all sorts of strange things happen.  I've troubleshot it twice on my own cars and dozens of times when I worked at a 2-way radio shop.  On my cars, both times it was due to negative/ground wires that corroded inside the insulation where you couldn't see it, leaving only a few strands to carry the current.  No sudden failures, and not intermittent.  Just a gradual worsening of symptoms.
Years ago when a rebuilt alternator was $75 that might be good advice.  I looked up a 2005 rebuilt Focus alternator at NAPA and they're going for about $175.  That's an expensive "try it and see".  It would only take a few minutes to check the grounds with a voltmeter.  That would include the radio grounds too.  If the negative power lead for the radio is compromised it could be getting return current through the coax, which can also cause wonky behavior.
KI4SDY
« Reply #22 on: September 08, 2012, 07:00:15 AM »
Excellent advice and "how to" information from K5LXP on checking ground connections. It could be that replacing an alternator has worked in some cases because the ground connection was improved during the swap out. Grin
Auto Zone sells alternators for most vehicles, including Fords, with a "limited lifetime warranty" starting at $129.00, plus a $9.95 core charge and tax. Unfortunately, a lot of auto parts suppliers will not let you return an electrical part if the problem is found to be somewhere else. That includes Auto Zone. Check those grounds first! Wink
K1CJS
« Reply #23 on: September 08, 2012, 08:45:52 AM »
Check the ground strap(s) between the engine and the firewall/fender.  That is the first place that I would look.  If you can't find one, try putting a heavy wire from an engine bolt to the bolt on the car where the negative battery terminal is grounded.  If the whine disappears, you know you've got to look for and replace that/those ground strap(s) that are going bad.
« Reply #24 on: September 08, 2012, 11:30:06 AM »
Again these ground strap solutions are more for a new installation with problems not a old one that has suddenly got noisy.
« Reply #25 on: September 08, 2012, 02:56:37 PM »
Well, lots of things just suddenly go bad, and cause a ground loop to appear out of nowhere. I will agree that older alternator diode banks aren't as good as the newer ones, but if it is a bad alternator diode, the whine will be very raspy sounding compared to one caused by a ground loop. Easy to check with an O-scope.
If you lose the fuse in the negative lead (for whatever reason), and draw power through the antenna connection of chassis of the transceiver, bingo! Even losing the battery's chassis ground, and relying on the engine ground can cause the same issue.
As Mark said, been there, done that!
K6AER
« Reply #26 on: September 16, 2012, 08:21:44 PM »
I will lay odds it is the alternator. Put a volt meter on the battery leads and place the volt meter in the AC mode. If you read any AC voltage the alternator has a bad rectifier.
