Author Topic: will this work?  (Read 778 times)
K5BDJ
« on: September 05, 2012, 07:51:56 PM »
I have a Radio Works Line Isolator.   I THINK it is a piece of coax, with ferrite beads installed, in a case.   Coax connectors on each end.
I have an "Ugly Balun" (coax would on a big coil, closely spaced).
I could use the "Ugly Balun" as a means of connecting my cox to the downlead (450 ohm twinlead) of a G5FV.
Would using the Radio Works Line Isolator work just as well in this application?
Using the Radio Works Line Isolator Will give me a sleeker looking installation.
K7KBN
« Reply #1 on: September 05, 2012, 08:35:54 PM »
Try it and see which one works better.
Pat K7KBN
CWO4 USNR Ret.
N4CR
« Reply #2 on: September 05, 2012, 09:47:57 PM »
You take all the fun out of guessing  Cheesy
73 de N4CR, Phil
WX7G
« Reply #3 on: September 05, 2012, 10:47:00 PM »
The ferrite "line isolator" should be much better than the ugly balun.
K5BDJ
« Reply #4 on: September 06, 2012, 07:20:05 AM »
Thanks for the thoughts!    I'll use the "line isolator".
It'll be a much cleaner installation.
