Author Topic: Right Metal?  (Read 1328 times)
KE5PPH
« on: September 06, 2012, 10:19:03 AM »
I need to make an Riser / extension from my Breedlove mount to the top of my roof line, So I can place a fold over joint in my whip.  I'm running the SGC / 102" combo. and trees and low drooping power lines dictate I lay it down while driving the Suburbs.  Can I use threaded Aluminum or brass rod?
KQ6Q
« Reply #1 on: September 06, 2012, 10:40:31 AM »
Hustler makes two lengths of foldover mobile mast segments - sounds like just what you need.
KE5PPH
« Reply #2 on: September 06, 2012, 06:41:54 PM »
Yep, and neither is the right length. Sad
KC7YE
« Reply #3 on: September 07, 2012, 06:55:09 AM »
Breedlove make a  fold over fitting .
« Reply #4 on: September 07, 2012, 08:00:13 AM »
I wouldn't use a Hustler mast because the shortest one with a fold over is 50 some inches long. As someone mentioned, Breedlove does make a fold over which will work fine. A short mast may be purchased from any one of a dozen sources. Wilson make several from 6 inches, to 4 feet.
KE5PPH
« Reply #5 on: September 07, 2012, 06:12:35 PM »
I have a joint to make the mast, and Hank recommended using the Brass.  That's why I'll buy stuff from him again.
