Author Topic: HRD question  (Read 1969 times)
KC9LJO
« on: September 07, 2012, 12:34:57 AM »
I am trying to setup my TS 680s on HRD. I know I have to turn on DTR, but for some reason I can not turn it on. What happens is I click the box and green check mark appears, but when I connect and it starts doing it's thing DTR is shown as OFF in the status box. And it can't read the frequency. Any ideas how to fix this?
Thanks
KD8GEH
« Reply #1 on: September 22, 2012, 08:29:04 AM »
Hi
Not enough info to help you .  What interface, operating system are you using?  HRD is a little tricky with communications errors.  If possible dont use usb converter cables, direct com ports always better.  Fixed many an issue with a 9 dollar pci card.
You can email direct if you like.  call at arrl dot net
Good luck,
Dave KD8GEH
WA4BLM
« Reply #2 on: October 07, 2012, 12:46:35 PM »
Don't know if this will help you with your TS-680 but I had to turn on CTS & RTS to get HRD to work with my Kenwood TS-2000.  I didn't have to do that with any other radios.  You might give that a try.
Good luck,
John WA4BLM
