Author Topic: FLdigi CW  (Read 7369 times)
AJ8MH
« on: September 22, 2012, 06:37:50 PM »
I'm wanting to use an LM567 decoder chip to drive a relay to key my transmitter when 600 Hz audio is detected from FLdigi.  I know you can get PTT from the com port, but has anyone tried the decoder route?  If so, have you noticed any delay keying the transmitter?  Any other issues?
Joe
JAHAM2BE
« Reply #1 on: September 22, 2012, 10:11:08 PM »
Is there any reason the transistor circuit proposed in the FLdigi documentation won't work for you?
http://www.w1hkj.com/FldigiHelp-3.20/CWkeying.html
That circuit is on my short list of upcoming projects to build.
PA0BLAH
« Reply #2 on: September 23, 2012, 03:43:45 AM »
Any other issues?
Joe
Joe, when the circuit locks there is a kind of bouncing at the open collector output, fast switching a number of times between OC and grd. So kind of debouncing after the circuit is probably required. That introduces a delay in the output.
So that may be an issue.
gd luck Bob
AJ8MH
« Reply #3 on: September 23, 2012, 06:25:56 AM »
I'm using line-level out of the computer and can't get enough drive to switch the transistor.  I played with the circuit yesterday, but haven't given up, yet.
AJ8MH
« Reply #4 on: September 23, 2012, 06:28:37 AM »
...debouncing after the circuit is probably required.
I'll keep that in mind if I go that route.  Thanks!
AJ8MH
« Reply #5 on: September 23, 2012, 09:19:49 AM »
Today, after some sleep, I got the FLdigi published circuit working on the breadboard.  Seems I had FLdigi up all the way, but my sound card was only half way up.  Operator error!  Thanks for your help.
PA0BLAH
« Reply #6 on: September 24, 2012, 07:24:26 AM »
OK congrats, must be, I watched the schematic of which  the link was given, and that must do what it is intended for. If not your isolation transformer is not 1:1 and interchanging primary and secondary should work.
Bob
