Author Topic: Getting back in the saddle?  (Read 2741 times)
KC5YN
« on: September 26, 2012, 12:08:29 PM »
Been off the air for a few years, mainly due to family illness' and now wanting to get active again.
You opinions solicited, and yes the questions are pretty broad:
Mobile - looking at a FT8900, four bander for mobile use in daily driver. I guess two or three antennas would be required. The combination of cross-band repeater and multi-bands is attractive. But, will it handle all the new "stuff" which I'm just learning about?  (Stuff = technical advances old farts are slow to comprehend)
HT - Huh
Shack - Have a NIB D1000 with tuner. (In the other closet are an Atlas 210 and Swan mobile HF rig) The 'back yard' is 4 1/2 acres, so I'm open to most applications. Would like to do a little DX but more comfortable ragchewing. Besides a decent vertrical, would small tr-bander with maybe a 40 monobander under it be a good start. I don't plan on a lot of experimenting, so I want to try and get it right the first go around. (Last used was a TH6-DXX that worked well.)
Thanks for your thoughts,
Fred  KC5YN
Second time around Rookie
Law of Location: No matter where you go, there you are.
AD4U
« Reply #1 on: September 26, 2012, 02:23:46 PM »
I have a FT 8900 in my truck.  It works great.  I do not use the 10 meter band.  I have a Larsen 6 meter antenna with NMO mount.  I also have a Larsen 2 / 440 dual band antenna with NMO mount.  Since the USA version of the FT 8900 outputs all signals into one SO 239 you will need a diplexer to split the 6 meter signal from the 2 / 400 signals.
For just a little more $$$ you can purchase an all band all mode rig.
Dick  AD4U
KC5YN
« Reply #2 on: October 01, 2012, 07:30:39 AM »
Thanks for the thought Dick.
Is there an all-band, all mode mobile rig that will also crossband repeat?
Having an extra aerial or three on the truck is not a problem.
K1CJS
« Reply #3 on: October 01, 2012, 08:00:10 AM »
I believe the Kenwood TS 2000 will do crossband repeat.
