Author Topic: Need TS-440 (with IC-10) serial port programming command set  (Read 3369 times)
WB0GAZ
« on: September 29, 2012, 12:12:43 PM »
I could not find the serial programming command/response set defined in the TS-440 manual; where can I find a definition of the commands and responses used for programming a PC to control the rig?
Thanks!
W9GB
« Reply #1 on: September 29, 2012, 02:22:11 PM »
Do ou have the 2 integrated circuits added to the control board?
WB0GAZ
« Reply #2 on: September 29, 2012, 07:01:35 PM »
Yes, those parts are installed and it operates normally --- I am seeking a list (or definition) of the commands and responses that would be used by HRD, etc.. I can use HRD, etc. to control the radio, but I am trying to find a list of the underlying commands (format, parameters, etc.); it doesn't seem to be documented in the radio's manual itself.
Dave
WB0GAZ
« Reply #3 on: September 30, 2012, 07:35:14 AM »
Answer found in the next-most-obvious place - IC-10 manual - have found what I needed! Topic closed.
