Author Topic: FT-450/450AT 60 meter upgrade software  (Read 2912 times)
KF7CSO
« on: September 29, 2012, 07:29:03 PM »
The 60 meter software upgrade is now available for the original FT450/450AT on the Yaesu website.
Sorry if this is the wrong forum.
Eric
KG6BRG
« Reply #1 on: October 02, 2012, 06:33:39 AM »
Can you supply a link?  I don't see anything relating to a plain Jane ft-450.  Don't even see a support tab.  Thanks for any help.  cheers.
Found it.  thanks for the heads up.  scroll down a bit.
http://www.yaesu.com/indexvs.cfm?cmd=DisplayProducts&ProdCatID=102&encProdID=870B3CA7CFCB61E6A599B0EFEA2217E4&DivisionID=65&isArchived=0
« Last Edit: October 02, 2012, 07:23:43 AM by KG6BRG » Logged
KF7CSO
« Reply #2 on: October 02, 2012, 06:26:18 PM »
Your welcome. I can't do the upgrade for a bit. I don't have a computer with a DB9 and I don't want to try an adapter. Let me know how it works out either here or my email listed on QRZ.
Eric
Eric
N4NYY
« Reply #3 on: October 02, 2012, 07:28:55 PM »
Eric
Adapters work perfectly fine. I have updated my FT-950 several times with the adapter.
KF7CSO
« Reply #4 on: October 03, 2012, 05:40:35 AM »
Eric
I can't believe I spelled "you're" wrong.....Anyway, that is good to know. The instructions on the Yaesu website paint a bit of doom and gloom. Thanks.
Eric
KA1VF
« Reply #5 on: October 03, 2012, 05:10:39 PM »
   After fighting Murphy's Law for a couple of hours, I've successfully installed
   the latest (0228) firmware on my ancient Yaesu FT-450AT rig. I haven't as
   yet actually used the rig since the upgrade, but it did power up OK as 0228.
   note: my ancient Yaesu FT-450AT was manufactured April of 2007 in Japan.
            73 and good luck,
                                     Bob
KA1VF
« Reply #6 on: October 04, 2012, 01:51:34 PM »
Bug Report# 1:
                    I've given the new FT-450/FT-450AT (0228) firmware
                    a fairly extensive workout into an MFJ# 260C dummy.
                     The only obvious problem that I've encountered is that
                     it always transmits 100 watts on 6 meters regardless
                     of the power/mode that you've selected.
N4NYY
« Reply #7 on: October 04, 2012, 03:05:56 PM »
Check with the Yahoo group to see if that is normal. I would do a full reset, and Yaesu recommends a full reset. You will have to use a utility to save your settings, or just write them down and reenter them. My 950 takes about 5 minutes to reenter them manually.
KA1VF
« Reply #8 on: October 04, 2012, 05:54:57 PM »
As the popular saying goes "I've been there and I've done that". I did a full reset (Home/RCL/Power)
prior to upgrading from the old (0194) firmware to the new (0228) firmware. Then I did another full
reset (Home/RCL/Power) after the new (0228) firmware was successfully installed. Then I manually
reentered all of my CW mode customizations in VFO A and all of my Digital mode customizations in
VFO B before I began my bench testing.
N4NYY
« Reply #9 on: October 04, 2012, 06:01:42 PM »
I would call Yaesu and see what they say.
