Author Topic: Kenwood TM-D710A Lockup  (Read 745 times)
W0GXA
« on: October 02, 2012, 06:08:00 PM »
I'm looking for other Kenwood D710A owners who have had this problem....
I installed a new unit in my car a month ago and in my second week, I had the following happen twice:
The radio was set up to run APRS beacon on channel A (using Green Light GPS-710) and scanning VHF/UHF memories on side B.
I would hear a pop in the speaker, side B would stop scanning and after about 3-4 seconds, the unit would shut down.  While scanning was stopped, the decimal point continued to flash like it does when scanning has stopped on an active channel.  Since it pauses for 3-4 seconds, it sure doesn't seem like an intermittent power connection.
I ran the unit for two weeks not using APRS with no issues.  While this isn't proof, I suspect the radio received some bad data and doesn't handle the exception well and shuts down.
Anyone else seen this?
Other data:
R/T software is up to date.  I see I'm one version behind in control head (2.10).
R/T is mounted on structure between the rear speakers in the trunk.  Temps have been relatively cool this fall.
Always run on low power setting.
Power wires run from battery to R/T.  Only mechanical connections are at the battery, Kenwood supplied power cable connector and the fuse holder.  10ga.
73, Bob W0GXA
K6LCS
« Reply #1 on: October 07, 2012, 10:48:12 AM »
See if Don Arnold can assist you with this ... I believe he knows your radio model well ...
http://www.geosat.us/
Clint K6LCS
909-241-7666
Clint Bradford, K6LCS
http://www.work-sat.com
