Author Topic: MFJ 986 vs MFJ 989D  (Read 709 times)
KJ6TSX
« on: October 02, 2012, 09:39:32 PM »
What is the better tuner between the MFJ 986 and MFJ 989D?
The 986 is a differential "T" tuner the 989 is a "T" tuner what exactly does that mean?
Looking to buy a 1000 watt tuner these seem to be in my price range, any suggestions or comments?
Thanks
George
KJ6TSX
« Reply #1 on: October 02, 2012, 09:54:00 PM »
I just re-read the specs on the two tuners and realized that the 986 has 1 adj capacitor the 989D has two. I assume that makes it more precise???
« Reply #2 on: October 03, 2012, 09:06:25 AM »
The "differential" tuner still has two capacitors, but they are on a single shaft.
That is supposed to make it easier to adjust because there are fewer knobs.
The tradeoff is that the differential approach doesn't allow both capacitors to
be near maximum capacitance.  For the same capacitor size, the differential will
always use less capacitance than the standard "T" network, which means that
efficiency may be less.  Much of the time this won't matter much, but if you
are matching low impedance loads on the lower bands (80m and 160m) it can
be important.
In practice, with a conventional "T" network I try to leave one or the other
capacitor at maximum and just adjust the other (although some loads won't
match this way).  That means, most of the time, I'm only dealing with one knob
in addition to the inductor anyway.
KJ6TSX
« Reply #3 on: October 03, 2012, 02:55:56 PM »
Thanks for the reply
Now I Know and it even made sense
Thanks
George
