Author Topic: Balanced feed-line running along concrete roof tiles  (Read 2682 times)
KG6SII
« on: October 03, 2012, 04:08:06 PM »
I have about a 10ft section of 300Ohm twin-lead laying on my concrete roof tiles, from a vent to the center of my dipole.  Do I need to insulate the twin-lead from the concrete roof?
Glenn KG6SII
W5DXP
« Reply #1 on: October 04, 2012, 06:08:21 AM »
A possible clue would be to measure the impedance (or SWR) under dry and wet conditions. Ordinary concrete absorbs water which could have a large effect on twinlead.
W8JI
« Reply #2 on: October 04, 2012, 06:49:42 AM »
Glenn KG6SII
It is never a good idea to lay an unshielded  balanced line on anything. It should always be ***spaced *** several line widths away from other things, including roofs or dirt.
Insulation does not help, air spacing does.
WB4SPT
« Reply #3 on: October 14, 2012, 05:56:30 PM »
I don't think "dry" cement tile will affect your signal much.  But, I will say the tile will be abrasive and tear up your PE insulation.
KA7NIQ
« Reply #4 on: October 21, 2012, 08:03:01 AM »
Glenn KG6SII
Well, I own a tile roof cleaning company here in the Tampa area www.saferoofcleaning.com and see moisture up there quite a lot.
The tiles on a roof can and do get wet, and retain water, from both the rain and humidity here in Florida.
I think the water might effect the twin lead, but you will have to measure to be sure.
