Author Topic: Dentron 1000 No current  (Read 1466 times)
KJ6TSX
« on: October 04, 2012, 11:09:09 PM »
Fired up my new Dentron 1000 amp I bought and everything worked well for about 20 minutes.  I attempted to tune the amp on 20 meters and had the load set at 1 instead of 5 were the manual says to start, I heard a odd sound and immediately unkeyed (1 or 2 seconds) after that the amp will not transmit. I have aprox 900 volts (Same) But absolutely no current.(had aprox 400ma before) The transmit light comes on, however I remember a relay sound that I don't hear now.
Any advice were to start would be appreciated
Thanks
George
W1QJ
« Reply #1 on: October 05, 2012, 03:11:31 AM »
check the wiring you use to key the relay from the radio to the amp ans straight thru to the relay itself.  Make sure you have voltage at the relay.
KJ6TSX
« Reply #2 on: October 06, 2012, 10:02:09 PM »
Thanks for the Help!!
I found the problem a loose ground wire. new nut on the stud and working better than ever
73's
George
