Author Topic: Sanyo 1.2V NICD akku 26mm X 30.5mm  (Read 14524 times)
HG5AZR
« on: October 05, 2012, 08:52:42 AM »
Hi!
I like to buy Sanyo 1.2V NICD akku 26mm X 30.5mm.
I saw lot of website,but it seems doesnt exist .
Any suggestion?
Thanks
             Zoli
W9GB
« Reply #1 on: October 05, 2012, 09:34:54 AM »
Standard Battery Sizes - Wikipedia
http://en.wikipedia.org/wiki/List_of_battery_sizes
A "C" battery cell is 26 mm in diameter, BUT 50 mm in length.
http://en.wikipedia.org/wiki/C_battery
There are 1/2, 3/5, and 2/3 sized "C" battery cells, some with Solder Tabs.
http://www.batterystore.com/Sanyo/N3000CR.htm
YOUR SIZE, fits as a 3/5 "C" battery cell.
http://www.powerstream.com/Size.htm
Battery Giant -- 3/5 C
3/5C-1100, Generic, NiCd, 3/5 C, 1.2v, 1100 mAh, Flat Top, 1 Pk
$5.90
https://www.batterygiant.com/Primary-Cells/showchem.asp?chem=NiCd
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-NIC0203(Other+Products).aspx?dsNavigation=Ns~product+Type%7C101%7C1%7C%2CNrc~id-3%2CN~4294873218&Title=2.4V+1000mAh+NiCd
DO YOU HAVE A SANYO BATTERY NUMBER ?
http://www.powerstream.com/NiB.htm
The Battery Store stocks Sanyo Ni-Cd batteries.
Sanyo batteries was purchased by Panasonic.
The battery industry has quickly moved to Lithium and metal formulated cells.
Panasonic battery catalog
http://www.panasonic.com/industrial/includes/pdf/Panasonic-Battery-Energy_catalog.pdf
HG5AZR
« Reply #2 on: October 05, 2012, 12:43:16 PM »
Hi!
Thanks for lot of information!
It seems that only at battery giant available,only NI-CD ,correct?
Powerstream.com has no this battery, I asked.
I try to order later ,registration...
Thanks
                Zoli
W9GB
« Reply #3 on: October 05, 2012, 02:08:55 PM »
For Eastern Europe, CODICO in Austria is Sanyo/Panasonic Distributor
http://www.codico.com/
HG5AZR
« Reply #4 on: October 06, 2012, 06:54:35 AM »
Hi!
1.I didnt find akku at www.codico.com
Are you sure?
2.Can you notice me if you find place in europe where I can order this akku?
3.It is difficult for me to order from USA,maybe I will solve this problem.
   I will find somebody he will send me 10 from this 26x30 mm akku from batterygiant,if I send money before.
Thanks
              Zoli
W9GB
« Reply #5 on: October 06, 2012, 09:08:36 AM »
AKKU (Hungarian) = BATTERY (English)
Sanyo
By April 2012, parent company Panasonic plans to terminate the Sanyo brand, however it will remain on some of the products where the Sanyo brand still holds value to consumers.
http://en.wikipedia.org/wiki/Sanyo
Sub-C batteries
http://www.shopwiki.com/l/Sanyo-1/2-Sub-C-NiCd-Cell-Battery-with-Tabs-650mAh
START with the company's distributors in your backyard (country/region).
1. Sanyo batteries bought out by Panasonic.
Panasonic Energy Products (batteries).
Cadnica is Sanyo/Panasonic brand name for Ni-Cd batteries
http://panasonic.net/energy/
Panasonic classifies these as Industrial batteries (NOT consumer batteries)
http://industrial.panasonic.com/www-ctlg/ctlg/qACC4000_WW.html
2. You do know that you have Sanyo mfg. facility in your country???
http://www.sanyo.hu/regional/subdir01/
Sanyo Hungary ltd.
2510 Dorog, industrial park, Hungary
telephone:+36-33-531-000,
Fax:+36-33-531-003
e-mail: info.hu.shg@Sanyo.com
2. Panasonic has web page for Hungary, and country specific distributors.
http://www.panasonic.hu/html/hu_HU/index_HU/index.html
SUB-C is an ODD SIZE, which is reason you are having problems finding exact replacement !
Farnell
http://uk.farnell.com/batteries-rechargeable
« Last Edit: October 06, 2012, 09:46:11 AM by W9GB » Logged
HG5AZR
« Reply #6 on: October 06, 2012, 12:26:22 PM »
Hi!
I tried all,it seems only from batterygiant has it.
Why not working?Always error,if I submit:
http://www.batterygiant.com/form_requestmsds.asp
I like to ask all datasheet,fast charging is possible for this akku or not?Can you try?
Zoli
W9GB
« Reply #7 on: October 06, 2012, 12:48:30 PM »
WHAT IS THE RADIO or ELECTRONIC DEVICE is this BATTERY (AKKU) is used in??
HG5AZR
« Reply #8 on: October 06, 2012, 12:56:00 PM »
Hi!
Icom IC-202S portable radio.
This radio uses this form of battery.
I like to get 10 of this battery.
Thanks
              Zoli
W9GB
« Reply #9 on: October 06, 2012, 05:18:25 PM »
OKAY, should have started with this information.
You are dealing with a 1970s radio design --- and based on 1970s battery technology.
Due to RoHS initiatives in European Union (EU), cadmium and lead are 2 elements subject to restrictions.
Icom IC-202S Owners Manual
http://www.icom.co.jp/world/support/download/manual/pdf/IC-202S.pdf
Page 5 shows your situation, the Icom IC-202S will work normal "C" dry cells (8 total at 1.5 V each).
They used 10 of the shorter Ni-Cd (sub-C) for Rechargeable, because those cells are 1.2 V each.
http://en.wikipedia.org/wiki/Nickel–cadmium_battery
Contact Icom Support (Japan) for options.
Within the European Union since 2002, Ni-Cd batteries can only be supplied for replacement purposes, although they can be supplied for certain specified types of new equipment such as medical devices.
Panasonic/Sanyo is also Japanese based -- so other battery options (Ni-Mh, etc.) may exist, such as using full sized C cell that is rechargeable.
Battery Giant (main web page)
« Last Edit: October 06, 2012, 05:30:40 PM by W9GB » Logged
HG5AZR
« Reply #10 on: October 09, 2012, 10:56:54 AM »
Hi!
I wrote same e-mail to batterygiant.com but I didnt get any answer.
1.Can you ask it by e-mail for datasheet for this akku?
2.Fast charging is possible with 1A?
3.Shipping cost to Hungary?Possible?
Thanks
               Zoli
