Author Topic: Excel data  (Read 7648 times)
W8JI
« on: October 05, 2012, 02:18:03 PM »
I'm excel dumb. I have a spreadsheet that I dump data from my VNA into. The data is S parameter data, and I convert it to  R j  and Z with standard formulas.
For example this formula converts 50 ohm normalized S11 Real or Imaginary  into R and j:
=50*((1+cell data)/(1-cell data))
The problem I have is normal measurement noise results in the S parameter being 1 or more. I get places where this happens. Here is an example:
1.00E+00   4.83E-02   #DIV/0!   55.07281020   #DIV/0!
This is because the S parameter measurement cell data at 1.00E+00 is really 1.00000, instead of 0.99999 or some more reasonable number. This error is just from normal measurement noise.
What I want is an IF statement that if cell data (let's say cell B67) is 1.00000 or more, then it should be considered B67=0.99999
The problem is I can't figure out how to do an IF statement mixed in with the formula. In other words I want to change this formula:
=50*((1+B67)/(1-B67))
to something where if B67 > 0.99999 then B67= 0.99999
I'd like to do this without altering the data in B67, just by altering the formula.
I could also set the lower number (1-B67) to never go below .0000001
Can anyone help with this?? There are thousands of cells in one measurement sweep.
Thanks, Tom
« Last Edit: October 05, 2012, 02:20:56 PM by W8JI » Logged
K0BT
« Reply #1 on: October 05, 2012, 03:13:35 PM »
Could you try this and see if it works?
=IF(B67<0.0000001,0.0000001,IF(B67>0.99999,0.99999,50*((1+B67)/(1-B67))))
Bob, K0BT
W8JI
« Reply #2 on: October 05, 2012, 06:57:41 PM »
Thanks Bob , but no. Doesn't work. I'll play around with it some more tomorrow.
N5NA
« Reply #3 on: October 05, 2012, 07:12:40 PM »
How about:
=50*((1+(IF(B67>0.9999,0.9999,B67)))/(1-(IF(B67>0.9999,0.9999,B67))))
Alan N5NA
K3AN
« Reply #4 on: October 05, 2012, 07:15:15 PM »
Is the value you're concerned with a number that is inputted, or is it the result of a calculation? If it's a number you inputted, you cannot use an if/then construct to change its value. What you need to do is leave that value as it's inputted, and then write an if/then statement for some other cell that is either the value of the input cell or 0.999, depending on the input cell's value.
Say B3 contains the inputted value, which may equal or exceed 1.0. Write a formula for the adjacent cell C3 such as
@IF(B3<1,B3,0.999)
If the first part of the statement is true then C3 will contain the value of B3, otherwise C3 will contain the value 0.999. Then use the cell C3 to carry out your further calculations.
« Reply #5 on: October 07, 2012, 10:18:53 PM »
Hi Tom,
Using your example of cell B67 containing the input variable to the equation, I believe you will find a simple version of the IF statement to be as follows:
=IF(B67<1,50*((1+B67)/(1-B67)),9999999)
The formula says that if B67 is <1 then use your formula otherwise return 9999999. There is no need to continually recompute the resultant if B67>=1.
You can of course change the number to the right of the comma to be any result you wish in the event B67>=1.
Glenn DJ0IQ and W9IQ
W8JI
« Reply #6 on: October 08, 2012, 12:49:05 AM »
Hi Tom,
Thank you Glen, that one did it. I just can't understand MS program help all the time. Although my formula was initially wrong, I have corrected it and can use the "IF" statement. :-)
« Reply #7 on: October 08, 2012, 01:47:56 AM »
Hi Tom,
I am glad it worked for you. I agree with your assessment of the Excel help  - it often provides cloudy clarification!
- Glenn Dj0IQ and W9IQ
W8JI
« Reply #8 on: October 09, 2012, 04:58:51 PM »
I had to make some changes to what you wrote, but I have it now. Thanks!
