Author Topic: FT-2000 CW sounds and 'looks' terrible...  (Read 731 times)
K0URN
« on: October 06, 2012, 01:31:09 PM »
Long story short...trying to help my elmer with digital.  FT-2000 and HRD(DM780). He can decode PSK, although looking at his waterfall, signals are not as clear and concise as my station(FT-450 and HRD).  He cannot decode RTTY or CW.  So I go over there and start poking around.  I confirm PSK decodes OK and decide to look at some CW signals just to investigate a bit...
The CW signals on the water fall are horrid and have tons of NOISE and appear distorted.  Looks nothing like on my waterfall where CW is simply a clean line of dits and dahs.  It also sounds like shit.  I operate CW, he does not.  You could hardly copy this.  Sounds like a woodpecker on a 2x4 and like it is overwhelming the speaker or the receiver with distortion.  S-meter is not pegged, volume is not too high, so I am a bit stumped.  I am not too familiar with his rig, but it is similar to mine and I cannot figure out why it sounds like crap(this is with all digital software shut down, just pure radio cw...)...
Not sure how else to describe this to you.. I have a DM780 screenshot showing the signal, but not sure how to attach in this forum...
Any thoughts from the FT-2000 guru's?
NR0U
N4CR
« Reply #1 on: October 06, 2012, 01:34:32 PM »
What is the sound card and interface?
73 de N4CR, Phil
K0URN
« Reply #2 on: October 06, 2012, 01:38:09 PM »
Signalink USB.  However, when I shut all that down, the rig sounds like crap...I now suspect that something is set wrong on the rig and that is the source of the problem.
TANAKASAN
« Reply #3 on: October 07, 2012, 12:45:20 AM »
I don't have an FT-2000 in front of me but this sounds like an interesting problem so I did some digging on your behalf.
Please check menu setting "092 rdSP CNTR LV". This alters the gain or loss of the Contour function with -15dB being the default value. One site I found highlights the following problem:
The rig's output remains clean up to the +15 dB point. However, at +16 and above, the onset of clipping is observed.  Notice in the graph above the +20 point does not peak with the expected +5db level over the +15 setting due to compression clipping at some point in the AF/DSP chain.
From this, we can see that using the contour in the peak mode, levels of +15 dB and less are needed to avoid distortion products unless the signal is low enough to be below the AGC action threshold.
http://ac0c.com/main/page_ft2k_roofing_filters_ft2000_dsp_filters.html
Tanakasan
K0URN
« Reply #4 on: October 07, 2012, 09:43:00 AM »
Thanks Tanakasan,
I will check this out.
Lance
NR0U
VA7CPC
« Reply #5 on: October 07, 2012, 05:45:45 PM »
FWIW --
Yes, it sounds like a problem with the rig settings.
Try finding a MW AM broadcast station (540 - 1600 kHz), and tuning it in in CW or SSB mode.  In either case, set the IF filter fairly wide.
If _that_ sounds bad, you will have a stable signal to use for adjusting things until it sounds good.
First check that the noise blanker is OFF.  A noise blanker (on any rig) wreaks havoc with any strong signal coming in.
And make sure that the AGC is turned on, and the RF preamp is off.
           Charles
K0URN
« Reply #6 on: October 10, 2012, 05:00:00 PM »
Thanks Gang,
I got it.  AM reception was great, so I just keep staring at the rig.  Remember it is my elmers FT-2000 not my FT-450...but
close enough that I suddenly noticed the notch filter!!!  It was on and cranked down.  So, I turn it off and BAM, CW and
RTTY signals decode and all is right in the world.
Whew, back to normal.
Lance
NR0U
TANAKASAN
« Reply #7 on: October 11, 2012, 06:22:33 AM »
When you have a rig with a front panel like the flight deck of Concorde then pilot error is a possibility  Smiley
Tanakasan
