Author Topic: FT817 keying  (Read 1213 times)
K0TBT
« on: May 23, 2008, 02:42:50 PM »
I'm toying with the idea of using an external keyer and a keyboard with my 817.  The K1EL CW Keyer is a very interesting device.
Now, the question....does the 817 use positive voltage or negative voltage for keying?  I've seaarched high and low across the web, and haven't as yet found the answer.
The K1EL keyer connects via the key jack and supports positive voltage keying only.
Thanks in advance.
Karl    KØTBT
P.S.  The eHam reviews on the keyer are interesting to read as is the website.
DJ1YFK
« Reply #1 on: May 23, 2008, 03:12:33 PM »
Positive keying. Like (almost?) every solid state rig made in the last 20 years.
73, Fabian
K0TBT
« Reply #2 on: May 23, 2008, 06:43:22 PM »
Thanks, Fabian
WQ3T
« Reply #3 on: May 27, 2008, 11:29:04 AM »
The K1EL Winkeyer USB with high voltage option will key up to 300 volts positive or negative, no jumper changes required. The only rig it won't key is a spark gap.
