Author Topic: CW Keying  (Read 11907 times)
KE4ILG
« Reply #15 on: October 16, 2012, 02:06:44 PM »
I had not considered the coax bringing water into the shack but it is possible.  As I stated the fluid leaking out of a tuner(any electronics for that matter) is a concern.  I will be putting up a new antena soon and will be very mindful to seal the coax at the antenna.  Thanks for the tip, Mike KE4ILG GySgt USMC Ret.
K7KBN
« Reply #16 on: October 16, 2012, 06:02:45 PM »
I'm assuming your tuner isn't designed for such high power as to require water cooling?  Grin
Did you disconnect the coax at the tuner and check?
Pat K7KBN
CWO4 USNR Ret.
WX4O
« Reply #17 on: October 16, 2012, 08:19:00 PM »
I don't know if this will work for you, but I just set the rig (IC-7200) to the AM broadcast band in CW mode, tune off of a station to get rid of the carrier tone, and practice CW that way. I only hear one tone. Seems simple to me. ?? Smiley
WJ0J
« Reply #18 on: October 16, 2012, 10:42:11 PM »
Yup, I will take the tuner and the antenna to someone local  who would be willing to let me test it with their antennas. That might clear up a few things.
WJ0J
« Reply #19 on: October 16, 2012, 10:44:57 PM »
Oops, I meant I will take the tuner and the rig to someone local .....
