Author Topic: flat ribbon rotor cable  (Read 1078 times)
W0NTS
« on: October 09, 2012, 03:13:46 PM »
I have several light duty antenna rotors that use (5) conductor flat ribbon cable. I have not been able to locate any of this once common cable. Does anyone know where I can obtain some? Angry  W0NTS
W9GB
« Reply #1 on: October 09, 2012, 05:43:49 PM »
Dennis -
I just checked, and it appears that Radio Shack (corp. catalog) only sells 3-conductor rotor cable.
The Wireman, Pres Jones - N8UG sells a 6-conductor rotor cable (for Yaesu rotors), that will work.
It's not ribbon/flat cable, but standard circular cable.
W9GB
« Reply #2 on: October 09, 2012, 06:52:17 PM »
I did find this wire source on the Internet, for 5-wire ribbon rotator cable (Eagle).
http://www.summitsource.com/eagle-automatic-rotor-rotator-cable-wire-5-conductor-75-ft-5-wire-rotator-rotor-cable-automatic-directional-outdoor-offair-tv-antenna-connection-p-10405.html
Allied Wire and Cable
http://www.awcwire.com/ProductSpec.aspx?id=Antenna-Rotor-Cable-PVC
N4JTE
« Reply #3 on: October 11, 2012, 05:04:09 PM »
Google atlas model train wire, used it fo a 5 band dipole.
Bob
W4JH
« Reply #4 on: October 18, 2012, 07:02:34 PM »
Take a look at underground sprinkler cable.  For example, Lowes.com item no. 391364 -- 5 conductor 18 gauge.
« Reply #5 on: October 18, 2012, 07:32:59 PM »
 I have used 5 conductor thermostate wire. It is usually 18 or 20 gauge, good size. You can get it at Home Depot or any HVAC supply house.It worked very well for me. 73 Jim W5JJG
