Pages: Prev 1 2 [3]   Go Down
Author Topic: PowerPoles  (Read 21352 times)
K3AN
« Reply #30 on: October 21, 2012, 07:01:41 AM »
Solder-only, but I use the PP size that's intended for the wire gauge of the cable I'm terminating. Never had a wire break due to it being stiff from the solder. Soldering also allows you to re-use the power pole. Yes, you can remove the metal terminal from the plastic housing in a non-destructive manner, even when it has been properly "snapped" into position.
Pages: Prev 1 2 [3]   Go Up
