Author Topic: RigBlaster II USB interface and TruTTY in FSK mode  (Read 802 times)
KA2UUP
« on: October 17, 2012, 06:05:57 AM »
Hi to all!
I recently got TruTTY in order to update my digital software on a new computer running Windows 7.  I got the software working fine.  However, I have RTTY running on AFSK because I have not found a setup that will work on FSK.  MMTTY from Makoto Mori is working well using the FSK.dll, which is what I have used for years in Windows XP.  In the case of TruTTY in FSK mode, i can get the radio to key and generate either a mark and space tone, but not the diddle, even though there is a TxD block in the setup.  My guess is that there is one setup where the DTR/RTS pins (1 and 2) blocks must be checked for it to work.
Thanks for any help you may be able to provide.
73 DE Bert, KA2UUP
W5DQ
« Reply #1 on: October 17, 2012, 10:23:00 AM »
Hi to all!
73 DE Bert, KA2UUP
Bert,
I don't know anything about TruTTY but this excerpt from the RBII manual might give you a clue ...
Step 2b: Configure the PC and Radio for RTTY FSK Operation
Presently, to our knowledge the only RTTY software that works with the
RIGblaster Plus II or any USB-to-serial interface is MMTTY, and that
only by using the author’s EXTFSK extension.
The reason is that USB to
serial interfaces will not go down to 45 baud.
Follow the MMTTY Help files for setting up the program using the
EXTFSK extension to use the correct COM port with PTT on RTS and
FSK keying on DTR.
Once configured, transmit with MMTTY and watch the PTT and CW
LEDs. The PTT LED should be on steadily and the CW LED should
flicker with the RTTY. Confirm with the radio’s monitor that the FSK
output sounds like RTTY.
You will also have to make sure that your mark and space tones a re
correct by setting the radio and/or the software so that transmit and
receive mark and space tones are correct. The only easy way to do
this is on the air.
So it looks like if you are not running MMTTY and EXTFSK extension, it might not work???
Just an observation.
Gene W5DQ
Gene W5DQ
Ridgecrest, CA - DM15dp
www.radioroom.org
KA2UUP
« Reply #2 on: October 17, 2012, 12:54:09 PM »
Gene,
Thanks for the prompt reply!  I suspect that MMTTY is light years ahead of the other software when it comes to FSK with USB.  When it comes to RTTY, TruTTY is stuck in the serial port era.  It is good software for the other modes and works very well.  So, it seems that unless they use Makoto's engine, the FSK part of TruTTY will have to be done AFSK.
Again, thanks!
73 DE Bert, KA2UUP
