Author Topic: Kenwood TS-140S, No signal meter movement in RX, TX power/ALC ok?  (Read 1539 times)
W7XLR
« on: October 21, 2012, 07:33:59 AM »
Just picked up a TS-140S, everything seems to be working fine other than no RX needle movement in any mode, or band. The meter movement itself seems fine as it works in TX showing power, and in ALC. Any ideas? Tnx Robert W7XLR.
KA4POL
« Reply #1 on: October 21, 2012, 07:52:39 AM »
Do you have any receive problems, i.e. weak or no RX?
W7XLR
« Reply #2 on: October 21, 2012, 07:54:09 AM »
My RX audio is fine in all modes, just no needle movement...
KA4POL
« Reply #3 on: October 21, 2012, 08:19:24 AM »
The meter gets its signal from the signal unit PCB via CN2. There it is switched by a relay. It may just be a contact problem. To find this out you would have to check the resistance of the contacts or measure the voltage before the relay.
KE3WD
« Reply #4 on: October 21, 2012, 10:18:35 AM »
Or tap on the relay with a spudger while observing meter action...
W7XLR
« Reply #5 on: October 21, 2012, 11:13:59 AM »
Thanks for the replies. I have cleaned the contacts, and rapped on relays (while monitoring a strong signal) no luck. I have found another anomaly-when RF gain is turned down S meter needle moves up to S9! Well seems it's more than a simple fix. Guess I will have to live with it, don't bug me too much, but will have to lie about the signal reports Shocked
Tnx again...
KA4POL
« Reply #6 on: October 21, 2012, 11:32:34 AM »
S meters are not the most accurate devices anyway. So giving an impression of signal strength is certainly good enough. If it is not the relay you will have to dig further into the circuit.
KA5IPF
« Reply #7 on: October 21, 2012, 03:39:16 PM »
Tnx again...
That's the way the RF Gain control works. As you turn down the gain the s-meter goes up.
FWIW, What does an S-meter reading have to do with a signal report?
Clif
KE3WD
« Reply #8 on: October 21, 2012, 04:12:48 PM »
Tnx again...
Great Scott, man, that is proper operation!
« Reply #9 on: October 21, 2012, 08:37:26 PM »
Tnx again...
Yes it is quite normal. I wonder if his AGC circuit is no working and not producing voltage for meter.
W7XLR
« Reply #10 on: October 22, 2012, 07:47:22 AM »
Thanks for letting me know that's normal operation for the s-meter to raise when the RF gain is turned down. I never turned down my gain on my FT-620B, and I just got this radio in a yard sale for $100, so I think I did ok...
G4IJE
« Reply #11 on: November 04, 2012, 01:20:34 AM »
Are you sure you have the AGC turned ON? I'm not particularly familiar with the TS-140S so it may be that the AGC cannot be turned off, in which case it may be faulty. Strong signals would sound very distorted without AGC, which may give you a clue to a faulty AGC circuit.
