Author Topic: Post within last 120 seconds  (Read 3195 times)
W8JI
« on: October 25, 2012, 10:07:09 AM »
The "last post from your IP within last 120 seconds" is annoying.  Smiley
When it comes up, I go back and wait. Then I click the post again. Then it says "duplicate post you already posted this". Then I check and it does not appear, so apparently I did not really post it even though eHam thinks I did.
So I just give up.
K4FMH
« Reply #1 on: October 25, 2012, 10:56:19 AM »
Tom,
I had the same thing happen yesterday....don't understand...since the post never occurred.
Frank
K4FMH
N2MG
Administrator
« Reply #2 on: October 26, 2012, 10:43:45 AM »
test
N2MG
Administrator
« Reply #3 on: October 26, 2012, 10:43:53 AM »
test
WA2ROK
« Reply #4 on: October 26, 2012, 10:44:25 AM »
test
N2MG
Administrator
« Reply #5 on: October 26, 2012, 10:48:59 AM »
Yup, I just verified that's a bug.
Changed the timeout for subsequent posts to 15 seconds which should be a decent workaround.
Will make a note of the issue.
Mike N2MG
edit: changed timeout to 15sec from 20sec
« Last Edit: October 26, 2012, 10:57:12 AM by N2MG » Logged
AC5UP
« Reply #6 on: October 26, 2012, 10:51:04 AM »
tset
N2MG
Administrator
« Reply #7 on: October 26, 2012, 10:53:49 AM »
One could also make a small tweak to the original post if one were so inclined... again, as a workaround.
W8JI
« Reply #8 on: October 26, 2012, 12:06:40 PM »
No,  that doesn't work.
The problem is eHam thinks you made a post somewhere within the last 120 seconds. Even if it is a different post, doesn't matter.  It stops your entirely new post.
Then, when you wait on the back window, and try to repost after 2 minutes, it says "you already made a post and this is a duplicate". This happens even if I make a whole new post in the clicked "back" window.
A shorter timer might work, because that would stop the initial freeze.
It looks like Mike sees the issue and has changed something. Smiley
W8JI
« Reply #9 on: October 26, 2012, 12:07:05 PM »
test
W8JI
« Reply #10 on: October 26, 2012, 12:07:42 PM »
test
It is cured now, thanks Mike.'
N2MG
Administrator
« Reply #11 on: October 26, 2012, 12:26:38 PM »
Oof, that really stinks!
NK7Z
« Reply #12 on: October 27, 2012, 06:37:40 AM »
Mike N2MG
THANK YOU!
Dave
For reviews and setups see: http://www.nk7z.net
