Author Topic: Communications  (Read 4237 times)
KC6BIU
« on: October 25, 2012, 04:18:53 PM »
I cannot understand why I can receive a very strong signal from a foreign country & not be able to communicate on the same frequency. Thank you
« Reply #1 on: October 25, 2012, 05:14:00 PM »
Is your transceiver set up correctly? Can you communicate with anyone?
« Reply #2 on: October 25, 2012, 07:36:43 PM »
Tell us about your ANTENNA, and also the band(s) and time of day...
W1EL
« Reply #3 on: October 26, 2012, 04:28:20 AM »
Is the guy working split?
W9GB
« Reply #4 on: October 26, 2012, 04:55:06 AM »
Quote from: KC6BIU
I cannot understand why I can receive a very strong signal from a foreign country & not be able to communicate on the same frequency. Thank you.
We assume your question is in regard to 40 meters and the differing allocations between ITU Regions 1, 2, 3 ??
This Wikipedia entry is not complete, but provides how the differences began (BTW, WW2 was a factor).
http://en.wikipedia.org/wiki/40-meter_band
Only since 2009, have international communications (split) been possible --- foreign country SW stations still exist in the 40 / 41 meter allocation.
w9gb
« Reply #5 on: October 26, 2012, 09:17:42 AM »
I'm guessing you mean the station is transmitting on one frequency and receiving on a different one.  A lot of "DX" does this, and "we" (Americans) have to use split-frequency operation to accommodate them.
KC6BIU
« Reply #6 on: October 26, 2012, 09:25:00 AM »
Thanks for the reply. Next time I will try using split frequency. It makes sense to me.
KH2G
« Reply #7 on: October 26, 2012, 07:53:22 PM »
There is also a strong possibility that your not being heard over  the big guns that you don't hear or he may have local QRN/QRM
Regards
Dick KH2G
W7KKK
« Reply #8 on: November 04, 2012, 10:40:37 AM »
I will suggest that they are running an amp and possibly a very nice beam that gives you a great signal.
Perhaps your station is lacking an adequate antenna system for him to hear you assuming all other factors have been considered.
M0HCN
« Reply #9 on: November 05, 2012, 10:56:53 AM »
In general on HF your aerial system makes more difference to the other guys ability to hear you then it does to your ability to hear the other guy.
This is because a poor aerial at your end attenuates both the wanted signal AND the band noise when you are receiving and with an even halfway decent radio the band noise rather then the rigs self noise sets the rx noise floor, on transmit however it reduces your radiated power without causing an equivalent reduction in the noise level at the receiver half a world away.
Look to your aerials.
Regards, Dan.
