Pages: Prev 1 ... 3 4 5 6 7 [8] 9 10 11 Next   Go Down
Author Topic: Is the KX3 all it's cracked up to be or fake?  (Read 170188 times)
AA4GA
« Reply #105 on: February 16, 2013, 06:40:13 AM »
I have a T-1 qrp tuner I occasionally use with EFs and EFHWs but mostly use frequency cut dipoles and hex beams  with my K-1 without a tuner and was wondering if there was something specific about the KX3 needing an ATU.
The tuner is nice to have, but there is nothing special about the KX3 that requires it...it's just looking for a 50 ohm load like every other modern radio.  If you've got a T1 and are happy with it, the only reason to opt for the built-in tuner is to have it built in.  I've got a T1, but wanted the tuner in the radio so I opted for it, and will be selling the T1.
AK4YH
« Reply #106 on: February 16, 2013, 09:10:08 AM »
Hello Jim,
I am doing fine right now with the KX3 without a tuner, but sometimes is is convenient to have it built-in when out somewhere and your antenna situation doesn't quite work. I use a Buddistick sometimes, and I can't quite get a good SWR on 30 and 20m outside my local coffee shop  Shocked .. I suspect a street light pole three feet away.. Anyway, there are cases when you can't string up a wire antenna quite properly, and the tuner helps. I can also use an end-fed long wire and tune on a few bands.. Can't beat that.. If you have the T1 though, you're all set there!
Have a great week-end,
Gil.
WB0KSL
« Reply #107 on: February 21, 2013, 12:24:31 PM »
I have an 817nd, and like it.  I'll probably get a KX-3 someday.  Each has its place.  Gotta admit the talk from "The guy with no callsign" about manpack radios brought back memories. Like the time I wound up flat on my manpack back on a frozen creek at Aberdeen Proving Ground, and couldn't get up without help.  43 years ago.  Thankfully, after finishing that "Green" school, at least I had an RTO to carry the durn thing when I needed it.
73 de WB0KSL, John
NO9E
« Reply #108 on: March 02, 2013, 01:48:11 PM »
The tuner in KX3 is important if one wants to work portable everywhere when having little time. Assume you are in the center of Helsinki or travel by bike in the Netherlands, have half an hr to lose and and want to make a few contacts. Everything needs to fit in a backpack and the setup needs to be inconspicuous and fast. With the tuner, one can through some random-length wires into a tree  and work on bands that are active at the moment.
Ignacy, NO9E
W1JKA
« Reply #109 on: March 03, 2013, 06:03:57 AM »
  Thank all you gents for the ATU input. I some what suspected it was a personal preference issue and not something specific to the rig but wasn't sure.
N4OI
« Reply #110 on: March 03, 2013, 05:04:13 PM »
Re: GILGSN Reply #103
[...] I am considering a KX3 for the SSB capability. Although I have no interest in or using SSB I can see the advantage of it being available in certain situations.
I am a CW-only op, but I do knock the dust off of the mic once in a while.  I have an attic dipole and choose to limit my SSB output power to about 50 watts due to RFI.  I rarely make any SSB contacts at all and DX is almost nil.  On the other hand, with CW I seem to work DX at will (about 200 countries confirmed), even at QRP levels.
Does anyone really use QRP SSB consistently?  I must be missing something here...
73 ES GOD BLESS U ES URS DE KEN N4OI  Grin
AA4GA
« Reply #111 on: March 03, 2013, 08:15:45 PM »
Yes, I think a lot of people do.  I don't - I've had exactly one SSB QSO since getting my KX3 in November.  But a lot of the SOTA folks operate SSB only at QRP power levels.  I'm on the FT817 Yahoo Group, and a lot of those folks seem to operate SSB only also.
It's not for me, but that's why they have a mode switch!
M0WAO
« Reply #112 on: March 04, 2013, 06:44:24 AM »
i use my kx3 only on ssb and made many contacts with or my inverted-v on the loft or with my pro-whip 10 meter fishing pole in a park. so yes, there are qrp ssb kx3 people out there.
WA2TPU
« Reply #113 on: March 04, 2013, 06:46:57 PM »
Yup!! I'm one of those KX-3 SSB guys.
I had a blast in the contest over the weekend..especially on 40. A couple shy of 60 countries worked in the contest at 5 watts.
SSB is my main mode now and I really enjoy the KX-3's features on SSB.
Best regards and many 72/73 to all.
Don sr. --WA2TPU --
N4OI
« Reply #114 on: March 05, 2013, 05:29:10 AM »
Don sr. --WA2TPU --
SSB must bring out the warts on my attic dipole....  Congratulations!
WA2TPU
« Reply #115 on: March 05, 2013, 11:37:57 AM »
to N4OI....Many thanks Ken. I had an interesting contact this morning on 40 meters ay 0956 UTC...I heard a very weak station saying "up 5"....when I finally identified who it was- TX5K- The Clipperton Island DX-pedition....I gave him a call at 7184.77 Mhz...I tried 22 times...YES!! 22 times
and finally got TX5K.....with ONE WATT on SSB...And I'm in the TX5K's online log.
Talk about LUCK and the use of a good antenna...No! I'm not bragging....I was totally surprised to even hear TX5K at that time of the day here when conditions have been so poorly.
Best regards and many 72/73.
Don sr. -- WA2TPU -- SSB QRP HERE!!
WA2TPU
« Reply #116 on: March 05, 2013, 11:40:08 AM »
To All........
Yes, the TX5K contact was with the BEST transceiver I've ever owned...The Elecraft KX-3 at ONE WATT.
Best regards and many 72/73 to All.
Don sr. --WA2TPU-- SSB QRP HERE!
AK4YH
« Reply #117 on: March 06, 2013, 12:06:17 PM »
You guys are missing out a lot not using CW with a KX3! I have even made contact using 100mW! Sure, it's frustrating to learn sometimes and takes a lot of time, but the rewards are worth the effort. It took me six months to become somewhat proficient. I use CW 95%+ of the time. 5W CW works as well as 100W SSB, simply because the power in SSB is spread over a much larger bandwidth. I bought a $2 microphone on Ebay for it and it works fine for the very few times I use phone. The KX3 is first and foremost a CW machine, in my opinion. The filtering down to 50Hz is absolutely amazing. I would have bought one even it it didn't have SSB. Hey, a KX2 would be great!
Gil.
AB7KT
« Reply #118 on: March 06, 2013, 01:51:39 PM »
This doesn't add anything to the discussion, just sort of an update. I posted earlier that reading this thread inspired me to purchase a KX3. I later posted that it was everything it was cracked up to be. And, after owning it for about three months now, my opinion of the radio has only gotten higher.
I initally hooked up my only antenna directly to the KX3 so that I could use the rig's internal tuner and in the process disconnected all the other rigs in my station. I found that I enjoyed the KX3 so much, I left it that way for about two months. I have always dabbled in QRP, but never real seriously. The KX3 pushed me over the edge. Not just because it is a terrific rig, but it was the first time I did a LOT of QRP operating and I found that I simply didn't need to run more than 5 watts on CW. Once I realized that, there was no turning back. I have since put the station back in order so I can use any radio I want, however I still use the internal tuner on the KX3 by putting my Palstar AT-Auto in bypass mode. However, I still have only used another radio one time since buying the KX3. I have been thinking about buying a new 100 watt HF transceiver for months now. I listed the features that I thought were a must for the new radio. After looking at the list, I realized that everything on the list, the KX3 had. Doesn't make a whole lotta sense to buy a new rig I guess.
In the first 57 days I owned the radio, I worked 100 DXCC entities and just got my QRP DXCC. I guess this doesn't say anything at all about the radio but is an endorcement for QRP power and simple wire antennas. I have made a number of contacts running 50 mw: I competed in the NAQCC milliwatt sprint using the KX3 and managed 18 contacts at 50 mw. I have used the KX3 on JT65 as well as PSK. 5 watts didn't really seem to hurt too bad.
I own a K1 as well as a KX1. I don't really see a comparison between the K1 and the KX3. For what it is, the K1 is a fun little rig, but the KX3 is in a whole different league. One is a pretty barebones rig while the other one is a full featured radio. I am not about to sell the K1, but it isn't a KX3 by a long shot.
I thought you said this was a weak signal mode ? I HAVE a weak signal and he still didn't hear me.
FWIW: My callsign is AB8KT
WA2TPU
« Reply #119 on: March 06, 2013, 02:30:04 PM »
To AB7KT.......
Congrads on the awards...especially the DXCC in less than TWO MONTHS!! I am honestly impressed with that accomplishment.
Your posting about the KX-3 is DEAD-ON TARGET...Its the best rig I've ever owned on ALL LEVELS in the many decades of being in this wonderful hobby.
Again, Congrads. I tip my hat to you.
Don sr. --WA2TPU --
Pages: Prev 1 ... 3 4 5 6 7 [8] 9 10 11 Next   Go Up
