Author Topic: Homemade Heil Proset Adapter? Anyone done this?  (Read 807 times)
W4JST
« on: October 27, 2012, 06:48:14 PM »
I have a Heil Proset 4 but no microphone adapter. With the adapter being around $20+ new I would like to make my own.
Has anyone made one? Is it just a matter of wiring to the correct pins for TX, audio, and the headphone jack or does there need to be a voltage change or a resistor/capacitor anything added in there?
May do this for a Yaesu FT-857D, 817ND or Kenwood TS-2000.
G0MGX
« Reply #1 on: October 27, 2012, 10:47:19 PM »
Hi
I recently bought a proset plus secondhand, it came with the wrong adaptor for my radios so I simply cut the connectors off and replaced with the ones for my rig - did away with an adaptor completely.
There's no components in the adaptor, the mic cable is a single core screened and the headphone lead a dual core version of the same.
Mark. G0MGX
W4JST
« Reply #2 on: October 28, 2012, 06:35:31 AM »
Thanks for the info!
Do I need to use shielded cable?
Two conductor for the mic and three conductor for the stereo headphones.
W4JST
« Reply #3 on: October 28, 2012, 06:47:29 AM »
I can plug the headphones right into the radio, I don't need to do any wiring there.
So I just need a mono, 2 conductor, cable for Mic/Audio and Mic ground for the mic.
And a 2 conductor mono plug for TX and TX ground in case I want to plug in a hand or footswitch.
Right?
Both of those need to be shielded cable or not really?
G0MGX
« Reply #4 on: October 28, 2012, 08:56:23 AM »
I would suggest shielded cable is always a good plan for audio at that impedence, so yes - you should use shielded cable.
Mark.
G0MGX
W4JST
« Reply #5 on: October 28, 2012, 04:38:32 PM »
Thank you!
