Author Topic: IERC tube shields  (Read 5955 times)
PCHAMNETPC
« on: October 29, 2012, 11:36:59 AM »
I'm restoring a R390-A ( a classic boat anchor of a receive if you ever saw one!) and have been casting around for the appropriate IERC tube shields. All's well except for the 6020-B which is a medium 9 pin shield. and seems to be scarce as hens teeth - probably because it's the most frequently used one. Can anybody help point me in an appropriate direction? No reasonable offer refused. Ideally i'd like 12, but 9 would do.
Thanx   Pete
N9LCD
« Reply #1 on: November 04, 2012, 03:14:54 PM »
Pete:
I've had a number of 390A's but I can't recall one with a 6020-A.  The only 9-pin tubes were the 5814A & the two rectifiers.  Maybe somebody "substituted" on you.  Which tube is it?  Where is it on the chassis or in the circuits.
Jerry
N9LCD
PS:  If you need shields for the 390A, try Fair Radio Sales in Lima, Ohio.  419-227-6573
AC5UP
« Reply #2 on: November 04, 2012, 03:29:43 PM »
Read the top post closely and you'll see the 6020-B is the part number of an IERC tube shield, not a tube.
Just for grins I looked up a 6020 tube and found no such animal, but there is a 6020 aluminum alloy.
The end of the world will occur on April 23, 2018 ( the day after Earth Day. Go Figure ).  If you're reading this on April 24th look for updates coming soon.  If you're reading this after June first, fuhgedaboudit.....
W9GB
« Reply #3 on: November 05, 2012, 06:33:33 PM »
Leeds Radio, Brooklyn, NY
http://leedsradio.com/
  IERC TR6-6015B, 9 pin min, for 6688, 5670, 6386 etc.  $8.00
  IERC TR6-5020H 9 pin min for 12AX7, E88CC, E803S etc $10.00
  IERC TR6-6020B, 9 pin min, for 12AX7, 12AU7,etc (rfe)$10.00
  IERC TRN6-6020B, 9 pin min, for 12AX7, 12AU7 etc.    $10.00
  Cinch TR6-6025B, 9 pin pin, for 6CG7, 12BH7 etc (rfe)$10.00
http://leedsradio.com/parts-sockets.html
