Author Topic: Can you identify this tower?  (Read 2275 times)
KB1UJS
« on: October 30, 2012, 11:40:13 AM »
Hi all. I am looking at buying a used self-supporting 40ish foot tower. Unfortunately, the seller lives several hours away and can't tell me exactly what he has for sale. I've attached the picture I have of the sections. They are all about 9' long, galvanized steel, and there are climbing pegs up one leg of the tower. The seller was told by someone the tower was made by Wade Antenna in Canada, but he can't confirm that and I found nothing on their web site that is comparable. Can anyone tell me what brand of tower this is and whether it will support a HyGain Explorer 14 tribander (7.5 sq ft wind load) with a Ham-IV rotator? Thanks.
Ken
http://forums.qrz.com/attachment.php?attachmentid=109032&d=1351615419
W9GB
« Reply #1 on: October 30, 2012, 01:36:55 PM »
Ken -
Wade Antenna DMX tower was very easy to find on the Internet.
http://www.wadeantenna.com/Wade/DMX.htm
Wade bought Delphi Towers (based in USA), that mfg. the DMX tower.
Here is specification brochure:
http://www.wadeantenna.com/Wade/DMX.pdf
These tower sections also look like the Thomas Shelby/Rohn BX Tower sections.
The BX series is NOT designed for large HF antennas.
http://www.criticaltowers.com/bx%20series%20towers/web%20pages/BX%20Series%20Tower%20Page.htm
Used Towers
http://www.usedtowers.com/bxtowers.htm
LOAD LIMITS
Wade/Delphi DMX Standard Duty Towers
are designed to support up to 3 square feet (0.28 square meters) projected wind area.
Hy-Gain Explorer EXP-14
http://www.hy-gain.com/Product.php?productid=EXP-14
PAGE 1-2 in the EXP-14 manual:  Wind Surface Area: 7.5 square feet (0.69 square meters)
Your Hy-Gain Explorer wind area is DOUBLE what the tower can support.
The standard DMX tower is NOT SUITABLE for the Hy-Gain EXP-14, Explorer !
« Last Edit: October 30, 2012, 01:54:48 PM by W9GB » Logged
« Reply #2 on: October 30, 2012, 01:41:47 PM »
Ken -
These tower sections look like (similar) to BX Tower sections.
Used Towers
I would NOT use this type of tower for an HF beam, such as the Explorer.
I thought that too for a moment, but I don't see the rivet holes on the photo he has; I don't think it's a BX type.  Might have braces welded-?  Really hard to tell.
In any case, as I posted on the other site, there are too many very good "known for certain" towers with complete engineering specifications available on the used market to take a chance on an unknown.  I'd pass.
N1CX
« Reply #3 on: October 30, 2012, 04:22:37 PM »
Looks like a 30' chunk of bx series.
Stuff stinks to work on it kills your feet, it's cheap, it's sharp, it's light duty.
It also most likely doesn't meet current wind specs so may have problems getting a permit if needed.
KB1UJS
« Reply #4 on: October 30, 2012, 04:39:43 PM »
Ken -
Used Towers
I wish I were closer to look at the tower.  I could probably find some markings on the tower sections to identify it.  I will probably end up passing on this one due to lack of info.
Does the BX series offer climbing pegs for the tower?  This tower has that and I can't find whether BX series towers had that available.  All I can find is numerous comments saying "don't climb BX tower - it's not designed for that!"
KB8BAB
« Reply #5 on: October 31, 2012, 06:29:45 PM »
Ken -
Used Towers
LOAD LIMITS
Looks like sections from a Rohn BX or perhaps even HBX...but like others have stated, it's hard to determine from the picture.
BTW, I have a 48ft Rohn BX (shortened at the top to 44ft) with a Hygain EXP 14 on top of it....handles it just fine..
« Reply #6 on: October 31, 2012, 07:00:42 PM »
It may handle it fine, but it could be impossible to get a permit for one with an engineering inspection, since the Rohn BX engineering documents clearly state that the tower is not rated for antennas having boom or element lengths longer than ten feet.  If you need a permit and an engineering review, this wouldn't fly for most HF beams.
If you don't need one, it might work for a long time!
WN2C
« Reply #7 on: October 31, 2012, 07:39:08 PM »
I have a HDBX w/ am A4S on it, mounted aproximately 1.5 ft above the top plate.  Been up for 6 yrs and no problem.  I talked with some one at AES in Milwaulkie or Cleveland and they had a bunch of beams for different bands (hf, 6, 2) on theirs, had it up for years with problems.
