Author Topic: Antenna length switch  (Read 1220 times)
W3KC
« on: October 30, 2012, 08:26:34 PM »
Goal: To change the length of a wire doublet via remote in-line switches (i.e. without traps).
Possibllities: - Mercury Tilt switches
                 - Pneumatic switches
Potential constraints - rf arc over
                            - contact current ratings
                            - weight
                            - wind resistance
Thoughts or other ideas ?
73 Chas
N3OX
« Reply #1 on: October 30, 2012, 09:34:23 PM »
Why?
Probably the biggest issue... can be handled at low power fairly easily.  At high power much harder.
Probably not a huge deal for any but the shortest antennas loaded very efficiently.
- weight
- wind resistance
Similar issues to traps, maybe a bit better if you can keep the voltages down, like in low power situations.
There have been a couple of cool designs in QST that do this... one with logic circuits and relays, the other with pneumatic switches.  But I think they're 'cool' mainly from a creativity standpoint.   Traps are a very good solution for a lot of reasons.  I've done antennas with relay switching; I have one I'm using right now:
http://www.n3ox.net/projects/2017moxon
and it has occasional problems on RX.  It's relatively manageable, especially after I sprayed relays with contact cleaner but it's not super reliable.  And my relays don't have to stand off the kind of voltage you see at the end of a resonant section.
I've built a lot of antennas with switches in them, even going pretty fancy (http://n3ox.net/projects/stepperswitch/) and over time I've come to prefer antennas that don't require any switching.  Just eliminates a lot of points of failure.  The new rotary vertical switch is very reliable so far but it has some power handling problems on 160m.  Arcs from the switch contact to the switch shaft above about 450W. If I need a single-vertical low band solution at another QTH I am probably going to try to build a super trap vertical with very high quality traps.
Any time you're relying on switch contacts at a high voltage point you may be in for a tough time.  And you have to keep a controller circuit alive.  No problem if it's a manual unit that's just a bunch of mechanical switches; more of a problem if you want to computer control it.
Dan
http://www.n3ox.net
K3VAT
« Reply #2 on: October 31, 2012, 04:20:33 AM »
                            - weight
                            - wind resistance
73 Chas
Yes, check out this site: http://mactenna.com/ - some have reported success especially running <1KW.
GL, 73, Rich, K3VAT
W5DXP
« Reply #3 on: October 31, 2012, 05:41:50 AM »
Goal: To change the length of a wire doublet via remote in-line switches ... ?
How about feeding a fixed wire doublet with parallel feedline and switching the length of the feedline to achieve system resonance? Switching is a lot easier on the ground close to the shack than 40 ft. in the air. The voltages encountered at the ends of a resonant dipole are very high, e.g. over 1000 volts for 100 watts, which exceeds the voltage rating of most affordable relays.
For instance, I'm about to put up a HEDZ (Half Extended Double Zepp) primarily for 80m/40m operation. EZNEC sez a 155 ft. dipole fed with 88 ft. of 450 ohm ladder-line will be resonant on both 80m and 40m. As a bonus, it is also near resonance on 17m and 15m. If one chooses to vary the length of the ladder-line between 73 ft. and 89 ft., all-band-HF coverage is possible without a tuner. Here are the feedline lengths predicted by EZNEC for a 155' dipole.
3.74 MHz, 88.3'; 7.15 MHz, 88.3'; 10.125 MHz, 76.6'; 14.2 MHz, 73.6'
18.14 MHz, 86.4'; 21.3 MHz, 88.1'; 24.95 MHz, 79.9'; 28.4 MHz, 78.1'
« Last Edit: October 31, 2012, 05:45:17 AM by W5DXP » Logged
73, Cecil, www.w5dxp.com
W3KC
« Reply #4 on: October 31, 2012, 06:57:30 AM »
My motivation was to be able to switch my 94 footer into a 44 footer and emphasize broadside radiation on 20 thru 10 meters.
73 Chas
N3OX
« Reply #5 on: October 31, 2012, 07:45:42 AM »
OK... that makes sense.  How much power you running?
I would consider something like pneumatics in this case because choking electrical control lines at the feedpoint of a multiband doublet could be very difficult.  It's different at the center of a switched resonant antenna because there you have a low impedance low voltage feedpoint.
If you go with something like a latching vacuum relay (Max Gain Systems has some), you could potentially use a second high voltage relay (maybe a more conventional one) to disconnect the control lines at the feedpoint.
The voltages across a 0.5pF set of switch contacts in your application is nearly 2kV at 1500W with a 14AWG 94 foot wire 30 feet over ground, so you'll want to find something with at LEAST a 2kV RF working voltage if you run legal limit.   It's roughly 500V at 100W.  If you use regular relays and not vacuum relays you should significantly oversize and may have to experiment because the voltage ratings probably won't be at RF.
You need to keep contact capacitance very, very low.  A few pF on 10m is enough to get substantial current in the "switched off" end sections and make the secondary lobes dominant.     If you use relays, the coil to contact capacitance should be considered carefully too.
I think it's going to be a little hard to get an electrically foolproof system that actually does what you want it to here. If you could use something like pneumatically or mechanically actuated knife switches that open up an inch gap or so, that might be the ideal in terms of electrical performance.
Dan
http://www.n3ox.net
W3KC
« Reply #6 on: October 31, 2012, 09:46:53 AM »
Thanks guys for your ideas and suggestion.
If I could come up with a low pass trap filter design that would isolate the 44' length for 14 mhz and up that would be dandy.
I generally operate at very modest power levels but I do have an amplifier available.
I might just wind up isolating the 44' with insulators and using jumper clips but it would be nice to not have to lower the antenna to make the switch over.
Again, thanks.
73 Chas
KB4QAA
« Reply #7 on: October 31, 2012, 11:55:00 AM »
Two words:  "Rube Goldberg"  (i.e. unnecessarily complicated)
Practical alternatives that maintain optimum pattern:
-Fan Dipole
-Trapped Dipole
W8JI
« Reply #8 on: November 01, 2012, 01:10:49 PM »
A 44 ft dipole covers 30 - 10, but a 90 ft dipole has a pretty high SWR on 80 meters. With a feedline SWR of 100:1 or more, some really weird things happen.
I'd never go shorter than 100-105 feet on 80 meters.
N3OX
« Reply #9 on: November 04, 2012, 01:03:22 PM »
I spent some of today working on a mechanical switch actuated by a pull rope that I might use for my short vertical antenna (http://www.n3ox.net/projects/n3oxflex)
Thought you might be interested...
http://youtu.be/I5cOsyQMbd8
I'm pretty sure I'm actually going to buy a $35 latching vacuum relay from Max Gain Systems instead but I figured I'd explore my options to keep it a pure mechanical system Grin
Dan
http://www.n3ox.net
K3VAT
« Reply #10 on: November 04, 2012, 01:12:24 PM »
Neat invention Dan - ... another PhD in mechanical engineering  Grin Grin
W4RS
« Reply #11 on: November 09, 2012, 04:19:19 PM »
do you go to any large hamfest? vacum relys are plentiful and not very exp. most are 24 volts.
