Author Topic: No transmit on 80 - Kenwood 440s  (Read 554 times)
WD0CCC
« on: November 02, 2012, 07:47:51 AM »
I purchased a Kenwood 440s at a hamfest last weekend that transmits only a couple watts out on 80 mtrs. The rest of the bands work fine. The seller had a pack of diodes for the RF board but I checked them front/back and the seem OK. Receives fine on 80 ... Any ideas?
KA4POL
« Reply #1 on: November 02, 2012, 10:13:30 AM »
Could be an issue with the LPF board like bad relay contacts. How does the power input for the rig change when switching between 80 m and other bands with good output. If you see no big change then this indicates the filter unit causing the problem. I assume your antenna isn't the cause. Or rather you used a dummy load.
